Old 12-14-2024, 12:23 PM   #11
51504bat
51504bat's Avatar
Default Re: Ford wide five wheel adapter
The 5/8" stud issue has been discussed before just not sure where. But there is a Dorman 1/2" stud that has the same shank as the 5/8" studs on the Speedway adapters. I can't remember the part number but hopefully someone will have it. With that number you can replace the 5/8" studs with 1/2" studs and solve the problem.
Edit:
Another option for adapters with 1/2" studs
https://www.racinginthedirt.com/prod...ide-5-adapters
