Old 12-13-2024, 11:25 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default Ford wide five wheel adapter
Anyone have a source on a Ford wide five wheel adapter? The one from Speedway has 5/8" lugs which, as they state, "Requires the use of our 1" hex lug nuts to retain the adapter to your hub", and will not fit the wide five wheels.
The lugs on the the 36-39 cars are 1/2" x 20 thread.
Thus, the Speedway wide five adapater, will not work on the 36-39 cars.
I have looked into having them made and can do it for $75, but hoped just to find one already made. I have seen other ones but they must have been made a long time ago.
I just need them for mounting and balancing, not for the road.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 12-14-2024, 01:25 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Ford wide five wheel adapter
Steve,Are you trying to adapt a later bolt pattern wheel to a
36 drum? I have used the Speedway adapter going from a 5.5 or 4.5 BP to the wide 5.
Old 12-14-2024, 06:04 AM   #3
Ggmac
I’ve used speedways also . Although I bought mine 15-20 years ago
Old 12-14-2024, 09:03 AM   #4
Steve in Denver
I just want to be able to get my tires changed and ballanced on machines that are set up for regular bolt patterns.
The Tire Stores all use that clamp style machine for tire changing and it has a hard time grabbing the rim. I have access to the old style tire machine, but it needs the smaller bolt pattern.
Steve in Denver
Old 12-14-2024, 09:38 AM   #5
fordyford
fordyford's Avatar
I made mine by turning the excess drum part off of a worn out 1937 front drum. Also cut out the hole large enough to fit on my tire machines.
fordyford is online now   Reply With Quote
Old 12-14-2024, 10:35 AM   #6
Zeke3
Zeke3's Avatar
Excellent, that is a great use for a worn out brake drum!
Zeke3 is offline   Reply With Quote
Old 12-14-2024, 10:38 AM   #7
Steve in Denver
I can have this made for $75 like someone did years ago. I'll just do that. Anyone else need one?
Steve in Denver
Old 12-14-2024, 11:51 AM   #8
34fordy
34fordy's Avatar
I remember going thru this a few years ago. I ended up buying a pair of racing adapters that allowed used of Ford wide 5 wheels. I did a “home” balance of the adapter plates. The 5/8” lug bolts slip into the wide 5 wheels just fine but the lug nuts were tapered differently. I took 5 nuts and turned the proper taper on them to match the taper on the wheels. I do not think that was necessary but did it anyway. It all worked well for me but I could not guarantee that my “home” balance was perfect. The tires I ended up putting on my pickup did not need any balancing for my 55 mph and less.
34fordy is offline   Reply With Quote
Old 12-14-2024, 12:05 PM   #9
Steve in Denver
I just do not understand why no one else just makes them correctly with the 1/2" studs.
Steve in Denver
Old 12-14-2024, 12:23 PM   #10
51504bat
51504bat's Avatar
The 5/8" stud issue has been discussed before just not sure where. But there is a Dorman 1/2" stud that has the same shank as the 5/8" studs on the Speedway adapters. I can't remember the part number but hopefully someone will have it. With that number you can replace the 5/8" studs with 1/2" studs and solve the problem.
Edit:
Another option for adapters with 1/2" studs
https://www.racinginthedirt.com/prod...ide-5-adapters
Old 12-14-2024, 12:31 PM   #11
34fordy
34fordy's Avatar
Like some many parts and tools there is not enough demand for a production run anymore. That is why we have to scrounge around and fabricate for ourselves. I believe it is part of the enjoyment of this hobby. The 5/8" studs slip nicely into the wide five wheel .
Old 12-14-2024, 12:56 PM   #12
ford38v8
ford38v8's Avatar
Steve, If you have a dozen made as you have suggested, you might sell one or two per year. That's why nobody makes them. Still, that's how many suppliers originally went into business, so go for it and good on you!
Alan
Old 12-14-2024, 12:57 PM   #13
Tim Ayers
Edit:
Dorman has an on-line catalog with all their studs with every dimension. If someone is willing to spend the time, it should be in there.
Old 12-14-2024, 01:15 PM   #14
Steve in Denver
I looked, they dont show prices, just who to buy them from.
https://www.dormanproducts.com/p-884...origin=keyword
I will go by Advanced Auto and Napa and see what they can find.
Steve in Denver
Old 12-14-2024, 01:24 PM   #15
34fordy
34fordy's Avatar
One more time: The 5/8 studs DO fit into the wide 5 wheels. PERFECTLY. All you need are 5/8" nuts. You are only wanting for mounting and balancing. No problem whatsoever. IMHO.
Old 12-14-2024, 01:54 PM   #16
Tim Ayers
Put the part number into Rock Auto's search. That's what I did. Here you go. $0.58 a piece
but it looks like they only have one.
Do the same thing on Google, I'm certain you will find a reseller.
https://www.rockauto.com/en/moreinfo...choice=0-0-8-1
Edit: Here is a set of six on Ebay
https://www.ebay.com/itm/354945103131
Old 12-14-2024, 02:29 PM   #17
Randy in ca
Randy in ca's Avatar
Here's a link to one of many past threads with information on the use of balancing beads rather than in the direction you're heading:
https://www.fordbarn.com/forum/showthread.php?t=303171
Randy in ca is offline   Reply With Quote
Old 12-14-2024, 03:07 PM   #18
34fordy
34fordy's Avatar
You cannot just pick any stud with a 5/8 shank. There are different sizes and the hole has to the proper diameter for the shank. The 5/8 shank will just fall into a 5/8 hole.
Old 12-14-2024, 04:35 PM   #19
Tim Ayers
Dorman catalog gives all the specs if you take the time to look through it
Old 12-14-2024, 05:20 PM   #20
34fordy
34fordy's Avatar
That is correct Tim, however in my little experience I have found it not exactly easy peasy. Some shanks have splines and some do not. If you are putting them into aluminum it is much more forgiving than steel. I have also found that a small bench press is not sufficient to set a stud, even in aluminum. A HEALTHY hammer on a solid base to work on has been necessary for me. Very possibly I have erred when I have done this. It is not always easy to find good information (for me) the first time I attempt something. Trial and error seems to be my forte. LOL
