Old 10-26-2024, 10:22 AM   #11
glennpm
glennpm's Avatar
Default Re: Bleeding brakes-pedal pressure problem. Could use some advice/suggestions
Originally Posted by acchaplin View Post
Ok, measuring with my 6" machinest scale,,,,,,,, I'm partly guessing (because i am not looking straight on) there is 3 and 3/8" from the center of the pedal pivot to the center of the pin that goes through the MC rod clevis, or that hole in the bottom of the pedal. Am I making any sense? Thanks
I have a '32 and from the center of the shaft to the pedal mounting bolt is 13"
So for you: 13"/3.375 = 3.85 ratio
(My ratio is 13/3 = 4.33)
Almost all hydraulic converted systems for '32s will have similar ratios since the MC pushrods are below the K member.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
