Old 10-23-2024, 09:24 AM   #11
glennpm
glennpm's Avatar
Default Re: Bleeding brakes-pedal pressure problem. Could use some advice/suggestions
After a lot of searching, this is the closest I could find that looks like your MC. https://www.performanceonline.com/19...R-DRUM-BRAKES/
From the searching, it is likely that you don't have residual check valves in your MC. When you rebuilt the MC from your bag of parts, did you have two of these, one for each port?
If you don't remember, push a paper clip it each port. If you feel resistance right away, you have a check valve in that port. check both front and rear.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
