Old 05-02-2026, 10:22 AM   #1
Ngnear22
Ngnear22's Avatar
Default 35 - 36 Ford Pickup Front Fender Hole Question
My 36 PU front fenders have rectangular openings for the bumper bracket vs slots, but maybe this question is applicable to either year. There are three 9/64 inch diameter holes on the bolt hole flange on cab side located at about 10 3/4, 15 3/4, and 20 1/4 inch from the running board end on both fenders. Anyone know what these are for?
Ngnear22 is offline   Reply With Quote
Old 05-02-2026, 11:37 AM   #2
nelsb01
nelsb01's Avatar
Default Re: 35 - 36 Ford Pickup Front Fender Hole Question
There are lower fender brackets. The main front fender bracket is the large bracket in which the headlights are attached. There is a lower one.
The picture is not the greatest, but it shows the lower fender bracket where it mounts to the inner fender and frame.
The bracket then uses carriage bolts to attach this bracket to the lip of the front fender.
nelsb01 is offline   Reply With Quote
Old 05-02-2026, 01:57 PM   #3
Don Rogers
Don Rogers's Avatar
Here is an image showing the underside of a front fender showing the holes.
1 Horn support hole
2 Headlight bolt hole
3 Front fender outer brace hole
4 Rear of front fender brace hole
Hope this helps!
Don Rogers is offline   Reply With Quote
Old 05-02-2026, 02:03 PM   #4
Kube
Super Moderator
Kube's Avatar
1 Horn support hole
Hope this helps!
Hello Don!
Old 05-02-2026, 02:06 PM   #5
nelsb01
nelsb01's Avatar
If they are on the inside of the fender, here is another photo. The inner fender panel does attach to the fender, and the remaining holes attach to the blind nuts in the cab cowl
Old 05-03-2026, 06:03 AM   #6
oldandtired
Ngnear22...The picture Mr. Rogers posted appears to be of the early 35 pickup front fender that had the "bar" across the bottom of the slot for the bumper brackets. The bumper bracket slot was open on the bottom on later 35's and the 36/7 pickups. The holes you asked about are the same. Good luck with your project.
oldandtired is offline   Reply With Quote
Old 05-05-2026, 08:37 AM   #7
Ngnear22
Ngnear22's Avatar
Thanks all for your replies. The rear brace behind the wheel bolt locations are challenging for me and this helps! But, the 3 small holes I'm wondering about are seen in nelsb01 photo of inside the fender, near the right side of photo (rear end of fender) and between the fender bolt holes. Maybe used to fix webbing?
Old 05-05-2026, 11:22 PM   #8
nelsb01
nelsb01's Avatar
Yes.
There were very small nails (for lack of proper term) used to attach the webbing.
I plan to use rubber cement when I finally attach the webbing.
Old 05-06-2026, 07:49 AM   #9
Model51
Model51's Avatar
Those small holes are for split rivets. Ford used these to hold the fender welting on a part. They are also used on things like the radiator splash shield. Third Gen sells a pack of them. I don't have the part number off-hand but if you call them I'm sure they can set you up. 844-327-5988
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 05-06-2026, 02:53 PM   #10
Ngnear22
Ngnear22's Avatar
Super! Going thru my inventory of forgotten parts last weekend and found rolls of fender welt and a pack of brass-colored split rivets, in different locations. Was wondering what they were used for. I don't even remember buying them. Time is an enemy to memory. Thanks for solving the mystery!
