Old 09-16-2025, 08:33 AM   #1
drezin
Default 35 vaporlock
having trouble with what I think is vaporlock. What are people using to plug the heat holes in the intake manifold?
I do have old original coil and condenser, that could be the problam
drezin is offline   Reply With Quote
Old 09-16-2025, 08:39 AM   #2
azlkk
azlkk's Avatar
Default Re: 35 vaporlock
Ed Smith used freeze plugs in the block on my engine. No real need for vaporization on Arizona cars.
'35 5 Window Deluxe Coupe w/radio- wife's uncle purchased new
Last edited by azlkk; 09-16-2025 at 05:21 PM. Reason: Added the fact that cold weather isn't an issue in Arizona.
azlkk is offline   Reply With Quote
Old 09-16-2025, 08:40 AM   #3
tubman
tubman's Avatar
I'm glad you added that last. I believe "vapor lock" has become a generalized term to cover a vast number of ignition problems. You seem to already know that your ignition system is not "up to snuff", so why not do something about that before chasing ghosts?
Old 09-16-2025, 09:12 AM   #4
drezin
I have an incorrect 37 intake on it now, putting the correct intake it now. thought I should plug the holes. Distributer will be sent off this winter
Old 09-16-2025, 12:24 PM   #5
Ggmac
I’ve always used copper pennies.
Ggmac is offline   Reply With Quote
Old 09-16-2025, 12:52 PM   #6
34fordy
34fordy's Avatar
Please explain.
34fordy is offline   Reply With Quote
Old 09-16-2025, 04:39 PM   #7
Merc Cruzer
Merc Cruzer's Avatar
Originally Posted by 34fordy View Post
Please explain.
To block off the round opening heat riser, between the block and the intake manifold
Merc Cruzer is offline   Reply With Quote
Old 09-16-2025, 04:46 PM   #8
tubman
tubman's Avatar
We don't know where Mr. "drezin" lives. Since he mentions "winter" in one of his posts, I don't imagine it's in the Magnolia Belt. Perhaps plugging the heat risers is not the best idea, especially with a weak coil and condenser. It will probably lead to eliminating "heat soak" in exchange for "carb icing".
Old 09-16-2025, 04:47 PM   #9
KiWinUS
KiWinUS's Avatar
Get your fuel pump and coil rebuilt.
