Old 07-01-2025, 08:55 PM   #1
oldford
Default What is going on with my 32 coupe top
The metal tack trim is under the top material. There are no signs of nails or stables. The top appears to be original. The trim should be on the outside with nails and rubber strip but it is not. The trim is metal because a magnet will stick to it. Can anyone tell me what is going on.
oldford is offline   Reply With Quote
Old 07-01-2025, 09:39 PM   #2
petehoovie
petehoovie's Avatar
Default Re: What is going on with my 32 coupe top
Old 07-02-2025, 12:15 AM   #3
DavidG
DavidG's Avatar
Post-production replacement.
Old 07-02-2025, 08:44 AM   #4
oldford
How was it done and why was it done this way. I cannot figure out how they secured the top to the car. It looks like the top material was folded under the tack strip then sat down on the car. But no signs of securing top to car. thanks
Old 07-02-2025, 09:04 AM   #5
Als48
Screwed or nailed from the underside?
Als48 is offline   Reply With Quote
Old 07-02-2025, 09:22 AM   #6
T Scott
Like Als48 said. I believe early Dodge and possibly other Chrysler cars were done this way.
T Scott is offline   Reply With Quote
Old 07-02-2025, 09:49 AM   #7
Tony, NY
It could be something like this metal flexible tack strip. Material gets hooked to the teeth and then it's flattened and tightens up the material. I've used this type on headliners. https://house2home-us.com/products/h...2r0o7txc&gQT=1
Try a putty knife to pry it up.
Tony, NY is offline   Reply With Quote
Old 07-02-2025, 10:11 AM   #8
oldford
OK, learn something everyday. thanks
Old 07-02-2025, 11:36 AM   #9
J Franklin
J Franklin's Avatar
I like it, super clean look.
Old 07-02-2025, 02:44 PM   #10
oldford
What tony said makes sense. I will be using the top as is but if I should ever try to replace, how would I get the top material tight using that flexible strip.
Old 07-02-2025, 06:00 PM   #11
Tony, NY
Here are a couple of Youtube videos. Not what you're doing, but the method would be similar. https://www.youtube.com/watch?v=Ef-e5KnUqAI
https://www.youtube.com/watch?v=ZqYhOe3rM7M
