The metal tack trim is under the top material. There are no signs of nails or stables. The top appears to be original. The trim should be on the outside with nails and rubber strip but it is not. The trim is metal because a magnet will stick to it. Can anyone tell me what is going on.
#2 | |
Post-production replacement.
Screwed or nailed from the underside?
It could be something like this metal flexible tack strip. Material gets hooked to the teeth and then it's flattened and tightens up the material. I've used this type on headliners. https://house2home-us.com/products/h...2r0o7txc&gQT=1
Try a putty knife to pry it up. |
OK, learn something everyday. thanks
I like it, super clean look.
What tony said makes sense. I will be using the top as is but if I should ever try to replace, how would I get the top material tight using that flexible strip.
Here are a couple of Youtube videos. Not what you're doing, but the method would be similar. https://www.youtube.com/watch?v=Ef-e5KnUqAI
https://www.youtube.com/watch?v=ZqYhOe3rM7M |
