Old 12-12-2024, 07:01 PM   #1
Wick
Wick's Avatar
Default Inside engine is Green?
Anyone know of a engine builder who painted the engines green inside?
Car has been in Virginia for a long time, been sitting since 2015.
I dropped the pan to clean it out...pan was clean.
Thanks Wick
Wick is offline   Reply With Quote
Old 12-12-2024, 08:03 PM   #2
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Inside engine is Green?
Thanks Wick
It sure is!!
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 12-12-2024, 09:00 PM   #3
jb-ob
Definitely a builder's signature. Aluminum cam gear ? Some effort was put into that rebuild.
jb-ob is offline   Reply With Quote
Old 12-12-2024, 09:24 PM   #4
bobbader
There is a spray can insulating varnish used for electrical fields and armatures that is pretty much the same color as shown in your pictures. Maybe somebody found it worked as well as normal internal engine sealers but was cheaper.
You know ................... "just when you think you've seen it all ..........."
bobbader is offline   Reply With Quote
Old 12-13-2024, 11:27 AM   #5
stevests
stevests's Avatar
I use Glyptal - it's reddish orange.
stevests is offline   Reply With Quote
Old 12-13-2024, 11:41 AM   #6
BillCNC
BillCNC's Avatar
Bad Idea!
There were some modern cars that painted the inside of the engine oil pan and it had very bad results. The paint flaked off and plugged up the oil screen instantly turning them into boat anchors. It was a very costly mistake.
The real question is why?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 12-13-2024, 12:16 PM   #7
katy
katy's Avatar
The Glyptal (insulating varnish used for electrical fields and armatures) that I'm familiar with has a gloss finish, not like the green shown in Wick's picture.
Old 12-13-2024, 12:40 PM   #8
gdmn852
gdmn852's Avatar
Hello, Hudson engines were painted with a sealing paint from the factory, was supposed to keep oil from sticking to inside casting , at least the 1948 to 54 engines were. Also Buick’s had inside differentials were also painted inside. Does sound like some effort was put into engine rebuilding.
gdmn852 is offline   Reply With Quote
Old 12-13-2024, 06:27 PM   #9
Hitman
I have a NOS Ford banjo that's painted a reddish color on the inside.
Hitman is offline   Reply With Quote
Old 12-13-2024, 09:10 PM   #10
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
The inside of front cover is orange. Looks line glyptol.
Crank counter weights look like BB crank with overhanging counter weights.
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 12-14-2024, 09:27 AM   #11
Wick
Wick's Avatar
I want to thank everyone for the information. The engine runs very strong and is smooth.
Car has a Mitchell overdrive and a/c .
I did find the pan tray was loose, bouncing around. I could hear something.
The crank has worn the tray badly, it actually has a Crack in it.
Lucky I happened to have a nice tray.
Wick
Old 12-15-2024, 12:10 PM   #12
Flathead
Flathead's Avatar
The ends of those cotter pins are kind of long, surprised builder didn't trim them a little.
Flathead is offline   Reply With Quote
Old 12-16-2024, 01:25 AM   #13
mass A man
mass A man's Avatar
I think it was on Fordbarn several years ago, an engine re-builder had used an epoxy paint inside crankcase for that purpose of oil not sticking to walls of engine but it was sort of a red as I remember. never saw the green until now.
mass A man is offline   Reply With Quote
