#1 |
Hi all. Question , has anyone ever used the speedway 5 speed conversion kit on a 49 - 53 ford ? If so , what all is to be done as far as fabrication .
#2 |
Are you referring to the T5?
#3 |
For the exception of cutting a hole in the floor for the shift lever and getting the drive shaft shortened. This is probably the cheapest and easiest conversion you can do. The adapter costs $160 (I'll look up the source) I think you have to use a T-5 with a Ford Bolt pattern but not sure. I made one of these adapters for Richard's conversion.
#4 |
Car or Truck?
Proud FNG We fixem cars. Heap Good! |
#5 |
Another good source is Cornhuskers.
#6 |
#7 |
If you are using the Mustang T5, the one behind the 4 cylinder has a longer input shaft. Modern driveline also makes a spacer(about 3/16 inch thick) to solve the problem
#8 |
Speedway has a complete conversion kit , transmission and all for 49 thru 53 flathead. I was just wondering what all is involved in the conversion. All the parts needed come in the kit. Has anyone ever used this setup. It uses a s 10 transmission.
#9 |
Give Gary at Cornhuskers a call. I bet he can match Speedway price
and provide info. you desire. |
#10 |
That is what I was referring to, Cornhuskers does a similar kit. Nothing against Speedway, I purchase a lot of parts from them, but if you need any support someone like Cornhuskers can provide it.
#11 |
I called Cornhuskers a couple yrs. ago and they were very good to talk too. But, his kits stopped at '48....... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#12 |
#13 |
It may have been just the bushing for the throw-out bearing that I was looking for.... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP Last edited by flatford8; 08-05-2016 at 09:42 AM. |
