Old 08-01-2016, 09:53 AM   #1
Goose1
Goose1's Avatar
Default Speedway 5 speed conversion
Hi all. Question , has anyone ever used the speedway 5 speed conversion kit on a 49 - 53 ford ? If so , what all is to be done as far as fabrication .
Goose1 is offline   Reply With Quote
Old 08-01-2016, 10:03 AM   #2
JSeery
JSeery's Avatar
Default Re: Speedway 5 speed conversion
Are you referring to the T5?
Old 08-01-2016, 02:11 PM   #3
Ol' Ron
Ol' Ron's Avatar
For the exception of cutting a hole in the floor for the shift lever and getting the drive shaft shortened. This is probably the cheapest and easiest conversion you can do. The adapter costs $160 (I'll look up the source) I think you have to use a T-5 with a Ford Bolt pattern but not sure. I made one of these adapters for Richard's conversion.
Old 08-01-2016, 05:18 PM   #4
jack orchard
Car or Truck?
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 08-01-2016, 05:31 PM   #5
JSeery
JSeery's Avatar
Another good source is Cornhuskers.
Old 08-01-2016, 10:24 PM   #6
Ol' Ron
Ol' Ron's Avatar
Modern driveline $167 T-5 adapter. Uses the stock clutch linkage.
Old 08-02-2016, 06:48 AM   #7
rick r
rick r's Avatar
If you are using the Mustang T5, the one behind the 4 cylinder has a longer input shaft. Modern driveline also makes a spacer(about 3/16 inch thick) to solve the problem
rick r is offline   Reply With Quote
Old 08-04-2016, 11:14 AM   #8
Goose1
Goose1's Avatar
Speedway has a complete conversion kit , transmission and all for 49 thru 53 flathead. I was just wondering what all is involved in the conversion. All the parts needed come in the kit. Has anyone ever used this setup. It uses a s 10 transmission.
Old 08-04-2016, 11:52 AM   #9
19Fordy
19Fordy's Avatar
Give Gary at Cornhuskers a call. I bet he can match Speedway price
and provide info. you desire.
Old 08-04-2016, 12:28 PM   #10
JSeery
JSeery's Avatar
That is what I was referring to, Cornhuskers does a similar kit. Nothing against Speedway, I purchase a lot of parts from them, but if you need any support someone like Cornhuskers can provide it.
Old 08-04-2016, 08:11 PM   #11
flatford8
flatford8's Avatar
I called Cornhuskers a couple yrs. ago and they were very good to talk too. But, his kits stopped at '48....... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 08-04-2016, 09:06 PM   #12
Straightpipes
Straightpipes's Avatar
Just bought a kit from Cornhuskers for my 8BA. He advertises them in the want add section.
Straightpipes is offline   Reply With Quote
Old 08-05-2016, 07:47 AM   #13
flatford8
flatford8's Avatar
It may have been just the bushing for the throw-out bearing that I was looking for.... Mark
Old 08-06-2016, 06:49 PM   #14
Flat Ernie
Flat Ernie's Avatar
The 4-cyl Mustang T5 is not all that strong...
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
