Old 12-05-2014, 06:44 PM   #1
my4dv8
Default 296 flathead , 48 strombergs.
We are building a 296 flathead and wish to keep the same Eddie Meyer twin hi rise manifold. What are the thoughts on running two 48 strombergs over two 97 strombergs. Before you say run 3 carbs , we want to keep the same look we have at present.
my4dv8 is offline   Reply With Quote
Old 12-05-2014, 07:07 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: 296 flathead , 48 strombergs.
Not much Ford in that picture.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 12-05-2014, 07:12 PM   #3
Kahuna
Kahuna's Avatar
I think it'll be great. I also like the offset 36 air cleaners
Kahuna is offline   Reply With Quote
Old 12-05-2014, 08:05 PM   #4
KiWinUS
KiWinUS's Avatar
Smile Re: 296 flathead , 48 strombergs.
Bruce
Beauty is in the eye of the beholder !!!!
A "Stunning Ford Flathead "!!!
Thank you .......
go for it !
All it needs is a KiWi-L100 cam
Cheers
Tony
Old 12-05-2014, 08:32 PM   #5
Ol' Ron
Ol' Ron's Avatar
Should work OK, depends on the application. Street rod yes, dragster no.
Old 12-05-2014, 08:57 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
I'm building a very similar combination for a hot street car (but 284 cubes). It is a heavily ported engine, 1.72" intakes, big roller cam , etc - really a total race motor (but not big on cubes) . . . I can't help myself!
The 48's are a bit bigger than the 97's - which is why I'm giving them a try. To me, the bigger issue is the design of the early EM manifold - probably isn't going to make much of a difference which carbs you run (I'm doing the same thing, original EM manifold of the same design).
Just for the heck of it, I'm going to put my car on a chassis dyno and screw around with a set of 97's, 48's and Holley 2110's (probably what we both really need). I'll also port the EM manifold and see if I can improve the flow.
My guess is that I'll see very minimal differences between all three sets of carbs - but what the heck, will be fun to have some REAL numbers to share!
Take care . . . ping me if you need additional information.
B&S
Old 12-05-2014, 09:09 PM   #7
PeterC
PeterC's Avatar
I'm happy with the performance and look achieved with the twin 48 Strombergs - they flow higher CFM needed for my application - 284 ci Flathead.
PeterC is offline   Reply With Quote
Old 12-05-2014, 10:29 PM   #8
uncle max
uncle max's Avatar
I am uncle max and I approve of this post.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 12-05-2014, 10:53 PM   #9
Pete
The vintage manifold doesn't match the modern heads.
That's just me though.
Old 12-05-2014, 11:53 PM   #10
my4dv8
Ha but it's what you can't see, it has an Cam techniques L100 cam , and this motor is going in another 32 we are building, and the new motor will have the "kiwi-L100 " cam we purchased off you.looking forward to hearing it rumble.
Thank you .......
go for it !
Cheers
Tony
Old 12-05-2014, 11:55 PM   #11
my4dv8
Excellent keep the barn posted on progress.
B&S
Old 12-06-2014, 12:02 AM   #12
my4dv8
Stock bodied all original 32 3W a hot rod for longer than it's been stock. all old ford or aftermarket ford parts, in essence a vintage hot rod , in our eyes anyway,
QUOTE=cmbrucew;992795]Not much Ford in that picture.
Bruce[/QUOTE]
Old 12-06-2014, 12:04 AM   #13
Pete
I may not be reading that right but I don't do L100's.
I don't like to infringe on Tony's business.
Old 12-06-2014, 02:05 AM   #14
my4dv8
Apologies Pete if I got something wrong but My reply was intended for Tony who has done the hard yards developing the Kiwi-L100 cam.
Old 12-06-2014, 04:45 AM   #15
Mart
Mart's Avatar
Tough crowd.
Old 12-06-2014, 05:10 AM   #16
JWL
There will be almost no performance difference from the 97 to the 48. Use whatever you have. As previously written about---for best results you need more on a different intake.
JWL is offline   Reply With Quote
Old 12-06-2014, 09:08 AM   #17
36tbird
I am running a 48 in the middle with the outer 97's dummied up on a .060 over 8BA Ford crank. With the original PV and jets it was way rich so I jetted it down as per Uncle Max's recommendations. So, with two, I think you might be rich if they are jetted stock. My 2 cents worth.
36tbird is offline   Reply With Quote
Old 12-06-2014, 11:30 AM   #18
Ol' Ron
Ol' Ron's Avatar
The 294/L-100 is running again and has over 1000 miles on it now. We have uncle max 97's at each end and a 48 in the middle. After Richard did his tune up the truck will light em up with a rolling start on just the 48, very impressive. I have the progressive set up to give 1/2 throttle on the 48, before the secondary 97's start to open. This limits them to about 3/4 throttle. But I don't think if will affect street performance and is nicer to drive.
Old 12-06-2014, 03:34 PM   #19
Pete
Maybe the owner just can't stand the neck wrenching torque an engine like that is capable of but it seems like a waste to limit it to partial throttle otherwise.
Old 12-06-2014, 06:08 PM   #20
Ol' Ron
Ol' Ron's Avatar
Partial throttle?? If I really wanted to get some power from the engine I'd run a 600 cfm 4 bl. If it wasn't for Max, that's what would be on it. Runs fine for a street machine.
