Old 06-08-2014, 09:35 PM   #1
Shadetree
Shadetree's Avatar
Default F1 Radiator Shroud
Did the F1 Ford pickups have a factory radiator fan shroud?
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 06-08-2014, 09:46 PM   #2
Catbob
Default Re: F1 Radiator Shroud
Been through 5 f-1s with both in line 6 and v-8 . Not seen a shroud on any of them. I ask the same question and was told by some old timers (older than me that at that time every effort to make an economical vehicle was put in to the pick up truck line. Such as only 1 wiper and 1 door key lock.
Catbob is offline   Reply With Quote
Old 06-08-2014, 09:57 PM   #3
Cody_1948
Cody_1948's Avatar
Yes they did, I have three for the inline six, If anyone needs one
Cody_1948 is offline   Reply With Quote
Old 06-08-2014, 10:04 PM   #4
40cpe
40cpe's Avatar
I have one that came out of a F2 with a V8. I can provide measurements if anyone wants to know if it will fit a F1.
The F2 radiator has a flange on each side of the core that the shroud bolts to. If the F1 has the flange, It could be an indication that it was equipped with the shroud.
40cpe is offline   Reply With Quote
Old 06-08-2014, 10:20 PM   #5
Ross F-1
Ross F-1's Avatar
Yes, here is one. Bill Boomer (4tford) got it for me out of a grain truck up in Saskatchewan. Not a great pic. Yes they bolt to the flange on the radiator.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-09-2014, 02:44 AM   #6
37coop
37coop's Avatar
I,v got one on my recently imported 51 f1 ,lucky to be there apparently,i was told most got junked for whatever reason ,I found it a bit fiddly when removing and replacing the fan assembly but I,m sure it helps cooling , cheers Jim.
37coop is offline   Reply With Quote
Old 06-09-2014, 03:36 AM   #7
Fibber Mcgee
Fibber Mcgee's Avatar
That's the one.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 06-09-2014, 05:21 AM   #8
Vic Piano
Vic Piano's Avatar
Our '51 F-1 V8 has a fan shroud and, most of the F-1's I've seen have them as well.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 06-09-2014, 08:17 AM   #9
mtflat
mtflat's Avatar
You've got to watch those "old timers". The 1 door key lock was a safety issue as Henry didn't want you to enter/exit or stand in traffic unlocking your door. You had to get in from the curb/sidewalk.
As far as one wiper, I went to the bother to hook up the second wiper on my 48 and found the linkage binds, causing more drag so I disconnected it. For 10 years of daily driving, I ran just one - the cab is narrow enough it's all you need.
Also keep in mind this was post-war. Chrome and stainless steel was abundant for civilian products again. These trucks came with a lot more shiny stuff than the 42-47's, so it wasn't all about keeping things cheap.
To the OP question, yes the F1's came with shrouds because they had the same cooling needs as big trucks. Later owners became lazy when they had to change hoses or waterpumps and eliminated them when replacing parts. Which in part, lead to people complaining that "flatheads run hot". If you have one, use it. If you don't, find one and reduce coolant temps - and not just the shroud, but the in hood deflector and the gravel pan.
mtflat is offline   Reply With Quote
Old 06-09-2014, 10:25 AM   #10
Steves46
Steves46's Avatar
PM sent. Thanks. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 06-10-2014, 02:49 PM   #11
jbrittonjr
jbrittonjr's Avatar
There are radiator shrouds on my F-1 (8 cylinder) panel truck and the F-3 (226 inline six).
jbrittonjr is offline   Reply With Quote
Old 04-22-2015, 10:34 PM   #12
BillAb
If you still have one of your F1 in line six shrouds I'd be very interested in one.
BillAb is offline   Reply With Quote
Old 04-23-2015, 06:56 AM   #13
Vanspeed
Vanspeed's Avatar
I just picked one up or my 48 v-8. Mine was missing, typical of farm trucks. I also suspect owners left them off after servicing the waterpump or something to make it easier on them. Almost all the trucks I see "in the field" are missing them as well.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 04-23-2015, 08:50 AM   #14
Barry-ct
Barry-ct's Avatar
MT has it right. They all had shrouds and the lower gravel pans. Most disappeared because of the pain to service the lower hoses, pumps, etc....
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 04-23-2015, 09:12 AM   #15
GreenMonster48
GreenMonster48's Avatar
Not to mention the hassle of getting the fan lined up in the center without it hitting the shroud. Life is so much easier without that thing.
GreenMonster48 is offline   Reply With Quote
Old 09-20-2015, 06:28 PM   #16
roggie
Question Re: F1 Radiator Shroud
Need shroud for Ford F1 pickup 1948. Call Gary 502-292-7470. Thanks.
roggie is offline   Reply With Quote
Old 03-25-2017, 09:56 PM   #17
Onlywood
Onlywood's Avatar
Anyone have a line on a fan shroud that would fit a 49 F-1 V8?
Onlywood is offline   Reply With Quote
Old 03-25-2017, 11:05 PM   #18
1948F-1Pickup
1948F-1Pickup's Avatar
I got one from fordyford awhile back for my '48 F-1.....
it's possible he may have another.
36 cord also told me he had one.
1948F-1Pickup is offline   Reply With Quote
Old 03-26-2017, 09:28 AM   #19
Onlywood
Onlywood's Avatar
Thanks, I'll see if I can make contact
