Old 12-26-2025, 11:20 AM   #21
petehoovie
petehoovie's Avatar
Default Re: Ford Script Battery
Originally Posted by corvette8n View Post
Found this in an old post.
Old 12-26-2025, 11:39 AM   #22
deuce_roadster
deuce_roadster's Avatar
Like Kube, I have a couple of the older script batteries that have an Optima inside and was wondering the same thing. I was considering cutting around the bottom of the case and around where the posts come up through the top with maybe a hole saw the right diameter without the drill bit. There must be something there, either epoxy or a sealer. The bottom could be glued back on with a new battery inside with epoxy if cut with a fine tooth saw blade.. Has anyone tried something like that?
Didn't see the Ken/Alabama post, was replying to Kube's, Thanks Ken, will try that.
Old 12-26-2025, 02:00 PM   #23
ford38v8
ford38v8's Avatar
This question has been asked and answered many times. There are several ways to skin this cat, and some of the older methods need modification today due to the taller Optima than in previous years. All methods have been described here on the Barn, seek and ye will find.
Alan
Old 12-26-2025, 02:33 PM   #24
Kube
Super Moderator
Kube's Avatar
I did seek but not find. Did you perhaps have any actual advice as to how I might perform this task?
Old 12-26-2025, 02:33 PM   #25
Model51
Model51's Avatar
There are several styles of original Ford Script battery cases. The dimensions changed over time and so did the exterior appearance. Some original Ford Script battery cases are too short to install a modern Optima 6 volt battery inside. For example the Type 40 for 1935 and a few other years, is 5/8" shorter than the optima. Some other years the case is taller. It all depends on exactly which battery you are using.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 12-26-2025, 02:34 PM   #26
Kube
Super Moderator
Kube's Avatar
Thank you. That seems to be a good approach.
You have a better method of searching previous threads than me
Much obliged.
Old 12-26-2025, 02:35 PM   #27
Kube
Super Moderator
Kube's Avatar
I have a couple of the "larger" cases found in 1940+. Having nothing much to lose by trying a retrofit, well, I'd figure I'd do just that; try.
Old 12-26-2025, 03:20 PM   #28
ford38v8
ford38v8's Avatar
mike, I guess my time is less valuable than yours. It took me a whole five minutes to locate my previous posts on the subject. Here's one that explains the whole process, but then, you are working with someone else's previous work, so who knows what you'll find:
https://www.fordbarn.com/forum/showt...ghlight=Optima
Alan
Old 12-26-2025, 04:39 PM   #29
Model51
Model51's Avatar
Here's a link to what I did for a shorter battery case. Scroll down to post #9
https://www.fordbarn.com/forum/showt...hlight=battery
Old 12-26-2025, 05:42 PM   #30
Kube
Super Moderator
Kube's Avatar
Thanks guys.
Old 12-26-2025, 08:59 PM   #31
stangblue
stangblue's Avatar
https://www.fordbarn.com/forum/album...ictureid=39935
Assumption is the mother of all foul-ups.
stangblue is offline   Reply With Quote
Old 12-27-2025, 04:38 PM   #32
russonator
russonator's Avatar
Thank you @stangblue. This is the post I've been waiting for.
russonator is offline   Reply With Quote
