Old 12-14-2024, 05:48 PM   #21
Tim Ayers
Default Re: Ford wide five wheel adapter
Originally Posted by 34fordy View Post
That is correct Tim, however in my little experience I have found it not exactly easy peasy. Some shanks have splines and some do not. If you are putting them into aluminum it is much more forgiving than steel. I have also found that a small bench press is not sufficient to set a stud, even in aluminum. A HEALTHY hammer on a solid base to work on has been necessary for me. Very possibly I have erred when I have done this. It is not always easy to find good information (for me) the first time I attempt something. Trial and error seems to be my forte. LOL
Believe me, I know. I spent a few hours finding the correct studs for the Boling Bros. slip on drums only to find out they sell the correct ones when asked. LOL! I believe they've since added them to their catalog.
Tim Ayers is online now   Reply With Quote
Old 12-15-2024, 12:59 AM   #22
deuce lover
deuce lover's Avatar
Originally Posted by Steve in Denver View Post
I can have this made for $75 like someone did years ago. I'll just do that. Anyone else need one?
Here is a pair on the HAMB $80.
Keep one and flip the other.
https://www.jalopyjournal.com/forum/...ptors.1328121/
deuce lover is offline   Reply With Quote
Old 09-02-2025, 09:14 AM   #23
Buckelew
Buckelew's Avatar
Hi Steve, I need to get at least one of these for the same purpose as you need them. Did you already get some made?
Buckelew is offline   Reply With Quote
Old 09-02-2025, 09:28 AM   #24
Steve in Denver
Steve in Denver's Avatar
I only had 5 made because no one else seemed interested in them.
Let me check with my guy to see how much he wants to make one or two.
I'm not sure I can sell 4 more besides yours.
Do you have any wide five friends that might want one.
A bulk order would help.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 09-02-2025, 11:09 AM   #25
Newc
Newc's Avatar
Spadero made them when in Business, he kept them in Stock. Now gone. Newc
Old 09-02-2025, 07:47 PM   #26
Tim Ayers
Since this has come up again, can I confirm what you are making, Steve? You are making an adaptor plate to use wide fives on a '40-style drum? If so, I am very interested in two pairs (4 total).
Old 09-02-2025, 08:08 PM   #27
Steve in Denver
well, sorta, I have made an adapter plate that goes from the wide five to a smaller diameter, similar to the pattern of the '40. Its purpose is to provide a way to mount the wide five wheel on a standard tire changer. It is NOT designed for road use.
Steve in Denver
Old 09-02-2025, 10:31 PM   #28
john greco
The only way to me to balance is find someone that can balance wheels on car ,
john greco is offline   Reply With Quote
Old 09-02-2025, 10:45 PM   #29
petehoovie
petehoovie's Avatar
Old 09-02-2025, 11:20 PM   #30
Lanny
Lanny's Avatar
So, just a quick question, Don't anyone use balance beads anymore ?
Are balance beads a thing of the past ? A flash in the pan ?
A big joke ? Or what say you guys ???
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 09-03-2025, 06:19 AM   #31
Tim Ayers
Ah, gotcha. In that case, I'm in for one for sure.
Old 09-03-2025, 08:35 AM   #32
Steve in Denver
ok, I will go by my guy today and see how his time is for making 5 more.
Buckelew wants one and Tim wants one.
If I get three more orders, it will be worth having them made.
I don't want to have three extras laying around.
Steve in Denver
Old 09-03-2025, 08:45 AM   #33
51504bat
51504bat's Avatar
I'd be interested in one as well, depending on the final cost. Thanks.
Tim
Old 09-03-2025, 06:56 PM   #34
Steve in Denver
Thanks, I will go by tomorrow, I ran out of time today.
Steve in Denver
Old 09-03-2025, 10:48 PM   #35
kc38ford
Steve, I'd be interested in buying an adapter too.
kc38ford is offline   Reply With Quote
Old 09-03-2025, 11:11 PM   #36
Phil Gillespie
Phil Gillespie's Avatar
Brought one from Speedway Motors a couple of years ago, Price and freight to NZ was great. Shipping was also very prompt.
Works real well.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 09-04-2025, 06:04 PM   #37
fordv8j
fordv8j's Avatar
I used a front brake drum, with bearings removed, balance drum first, install wheel with all lug nuts, then spin balance it, worked for me
fordv8j is offline   Reply With Quote
Old 09-05-2025, 08:44 PM   #38
Farley's34
Steve, I'm interested in one. Jeff
Farley's34 is offline   Reply With Quote
Old 09-06-2025, 07:45 AM   #39
34fordy
34fordy's Avatar
How did you balance your drum? On a machine? By removing metal or adding? With lug nuts or without? Sounds interesting! Don
34fordy is offline   Reply With Quote
Old 09-06-2025, 09:10 AM   #40
Steve in Denver
All,
My guy's shop is backed up. It will be October before he can get them made, he's a one man shop.
The cost will be $65 including lugs and standard lug nuts (not the original size lug nuts) plus shipping.
Steve
Contact me directly so we can stay in touch.
[email protected]
Steve in Denver
