Old 09-16-2025, 09:11 AM   #4
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Big oil loss on rear sid
My car started leaking more oil a couple of years ago. When I inspected the rear main bearing I found the babbitt bearing had come apart and the thrust surface broke off and lying in the pan. Sounds like you have the same problem but I hope not.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
