Old 03-17-2025, 03:46 PM   #1
kurt v
Default where to send rods to recondition
Need a place to send rods to get reconditioned, oba-6200 52 to 53 motor ?
thanks kurt
kurt v is offline   Reply With Quote
Old 03-17-2025, 04:54 PM   #2
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Default Re: where to send rods to recondition
You can send them to us.
We can rebuild them with new ARP nuts and new wrist pin bushings and even weight match them if you want?
https://www.jandm-machine.com/
J and M Machine is offline   Reply With Quote
Old 03-17-2025, 06:36 PM   #3
Krylon32
My local machine shop does them, has done many sets for me. Schmidt Machine, Fairbury NE.
Krylon32 is offline   Reply With Quote
Old 03-18-2025, 08:10 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
Hey J&M, how do you balance the big-ends? Where do you remove material from? Also, how do you install the pin bushings . . do you swage them in like Ford did?
Old 03-18-2025, 08:32 AM   #5
J and M Machine
We remove the material from the two ribs on the big end of connecting rod.
Typical set of V8 rods are usually within 6 grams as long as they haven't been swapped out.
Yes we have a tool prior to honing the wrist pin bushings that forces the bushing tightly against the rod prior to final honing.
Old 03-18-2025, 10:51 AM   #6
Shoebox
Shoebox's Avatar
Well, FWIW I just inquired with J&M about the cost of reconditioning a set of 8ba rods and was told..... to buy some Scat rods. Oh well.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 03-18-2025, 11:08 AM   #7
tubman
tubman's Avatar
Over $750 a set from Speedway. What do you want to bet J&M will also sell them to you; a lot more profit and less work than reconditioning, I'll bet.
And here I thought that another valuable asset just came forward. Oh well.
The guy at the local (Brainerd, MN) NAPA machine shop did mine for one hell of a lot less than that. "Shoebox", I see you live in rural Wisconsin; check and see if here is a shop near you that does tractors, etc. If a guy can do an 8N or 9N, a flathead would be a natural.
Old 03-18-2025, 11:13 AM   #8
tubman
tubman's Avatar
Sorry, duplicate post.
Old 03-18-2025, 02:53 PM   #9
J and M Machine
We would charge with the parts" ARP rod nuts/wrist pin bushings" would be $783 plus tax so in dollars and cents if you want price you can buy the scat rods before the tariff kicks in.
We don't sell parts as you can get them from Speedway or Summitracing.
Old 03-18-2025, 02:54 PM   #10
J and M Machine
You can try "Manitowoc machine in Wisconsin"
John
Old 03-18-2025, 03:07 PM   #11
Bored&Stroked
You can buy the H-beams from CNC-Motorsports for about $650:
https://cnc-motorsports.com/2-239-70...ting-rods.html
Old 03-18-2025, 03:10 PM   #12
Bored&Stroked
That was my guess. I don't prefer this method as it weakens the cap (in a non-stock build). The best method is to remove material from the sides of the caps (in a lathe) - the same way that Henry did it.
Sounds like you have the correct "swaging" tool for the bushings - that is good to know.
I made a fixture for my lathe to hold the cap - works great. Here are some pics:
Old 03-18-2025, 05:35 PM   #13
barnfind08
On my website I sell OBA-6211 rods with the hole for bearing which is different than the 8 BA6200 for with no hole. Exact replacement 50-53. They are $36.00 each plus postage
barnfind08 is online now   Reply With Quote
Old 03-18-2025, 07:14 PM   #14
Bored&Stroked
I would take up Barnfind08 on his parts and buy a NOS from him!
Old 03-19-2025, 08:23 AM   #15
kurt v
Already done.
Old 03-19-2025, 08:38 AM   #16
Tim Ayers
Fred had/has NOS French rods I believe.
Old 03-19-2025, 12:07 PM   #17
Shoebox
Shoebox's Avatar
I just did!
32 Ford roadster
39 Mercury Towncar
Old 03-21-2025, 11:04 AM   #18
my2nd40
my2nd40's Avatar
Where’s your website
my2nd40 is offline   Reply With Quote
Old 03-21-2025, 12:03 PM   #19
Bored&Stroked
https://southsideobsolete.com/
