Old 11-09-2024, 08:24 AM   #1
FrankWest
FrankWest's Avatar
Default zenith carb vs stromberg 97 carb
Which of these carbs is more reliable and less likely to clog.
FrankWest is offline   Reply With Quote
Old 11-09-2024, 09:41 AM   #2
nickthebandit
Default Re: zenith carb vs stromberg 97 carb
What vehicle / application would help us to help you.
nickthebandit is offline   Reply With Quote
Old 11-09-2024, 12:09 PM   #3
Kube
Super Moderator
Kube's Avatar
Less likely to clog? Debris in the fuel system will clog any carburetor.
Old 11-09-2024, 01:01 PM   #4
FrankWest
FrankWest's Avatar
1933 model B
Old 11-09-2024, 07:44 PM   #5
FrankWest
FrankWest's Avatar
Do you think it wise to put a fuel filter in the car. Funny , I guess originally these engines had no filter?
Old 11-09-2024, 09:05 PM   #6
cas3
your 4 banger has a fuel pump, so yes, I would make up a temporary line with a clear filter just to see if there is any junk in there. If its clean and you don't like the look then put the original line back on
