The Ford Barn
-   -   zenith carb vs stromberg 97 carb (https://www.fordbarn.com/forum/showthread.php?t=343795)
FrankWest 11-09-2024 08:24 AM
Which of these carbs is more reliable and less likely to clog.
nickthebandit 11-09-2024 09:41 AM
Re: zenith carb vs stromberg 97 carb
What vehicle / application would help us to help you.
Kube 11-09-2024 12:09 PM
Less likely to clog? Debris in the fuel system will clog any carburetor.
FrankWest 11-09-2024 01:01 PM
1933 model B
FrankWest 11-09-2024 07:44 PM
Do you think it wise to put a fuel filter in the car. Funny , I guess originally these engines had no filter?
cas3 11-09-2024 09:05 PM
your 4 banger has a fuel pump, so yes, I would make up a temporary line with a clear filter just to see if there is any junk in there. If its clean and you don't like the look then put the original line back on
