Old 07-31-2023, 06:39 PM   #41
petehoovie
petehoovie's Avatar
Default Re: 34 PU New project from an estate- all apart
Originally Posted by Newc View Post
Got some help today and finally put the cab on the chassis. A real bit of progress, and set up for the Winter work. The wood mount kit needed some fine tuning, but it worked. Don't expect those repro wood mounts to be perfect. Enjoy fellows -photos
Old 08-01-2023, 05:10 PM   #42
ShaunGoeckner
Hot DIGGITY!
I'll have to tap yer knowledge for my project!
I don't know why, but its got a Chevy 350 in it...
ShaunGoeckner is offline   Reply With Quote
Old 08-01-2023, 05:35 PM   #43
petehoovie
petehoovie's Avatar
Originally Posted by ShaunGoeckner View Post
Hot DIGGITY!
Old 08-01-2023, 08:28 PM   #44
totto
totto's Avatar
Looking good!!! You might have to modify your cab blocks as you stated, but that's OK. My '34 is stock but it is "your truck" and do it the way you want. It is on its way to becoming, "you can drive and have fun!!!" Keep us updated and I enjoy your excitement!!!
totto is offline   Reply With Quote
Old 08-01-2023, 08:54 PM   #45
tubman
tubman's Avatar
IMHO, narrower tires in the front would help a lot.
Old 01-19-2024, 06:28 PM   #46
Newc
Newc's Avatar
Been awhile: finally got back onto the 34 PU. We had 2" of ICE, VP of RG#85 broke his leg! So here is the latest:
Mounted radiator with the Drake Hose Kit. Set the fancy grill on for looks. Engine needed 5 washers on TOP of a MERC lift mount to clear for the fan belt [removal]. I even removed the crank guide bracket and used flat 'U' bolts for front spring. Installed the 'Quiet ride' Firewall pad- Very nice product, but needed some help. Installed the original cab wood- used 15 painted bolts and SHORTENED 12 of them for looks. Bolt ends protruding into passenger space [hazard]. Firewall parts next, engine has been tested a bit ago. Shocks ready to install. Thanks to the encouragement from followers. Expect to drive it this SUMMER! Newc
Old 01-19-2024, 07:22 PM   #47
petehoovie
petehoovie's Avatar
Old 01-19-2024, 07:41 PM   #48
DavidG
DavidG's Avatar
No front motor mount insulators?
Old 01-19-2024, 10:31 PM   #49
Seabees
Looking good Newc! Nice to see you're still in the shop!
Seabees is offline   Reply With Quote
Old 01-20-2024, 11:07 AM   #50
TJ
TJ's Avatar
Is that an aluminum spacer between the transmission and the drive shaft tube?
Old 01-20-2024, 11:27 AM   #51
petehoovie
petehoovie's Avatar
Looks like a ground strap to me...
Old 01-20-2024, 01:08 PM   #52
TJ
TJ's Avatar
Pete, I took a second look and you may be correct.
Old 01-31-2024, 06:43 PM   #53
Newc
Newc's Avatar
Saving OLD chrome-rusty back side. Grills, bumpers, ect always seem to have a POOR backside on chrome parts. This '34 PU grill was chromed in the '70's, brazed bottom edge, BUT the show surface is still good.
So it got wire brushed , cleaned off, and some derust magic applied. After drying; Sprayed with a good coat of bright silver enamel. REMEMBER to tape the holes before any of this is applied!!, even brushed into the open gill bars. I hope this grill lasts another 50yrs. I remember we always opened the grill bars [crimped shut] before working on a Ford grill. Drying in front of the stove. [Winter] Photo Newc
Old 01-31-2024, 06:45 PM   #54
petehoovie
petehoovie's Avatar
Old 01-31-2024, 07:13 PM   #55
Tim Ayers
Originally Posted by NealinCA View Post
I must still be about 13, because I like the chrome stacks. I think they fit the character with the chrome grill shell and later front bumper. It has a great 50's shop truck vibe.
100%. Love them and would keep them if they are in the parts pile. Total 50's vibe.
Old 02-01-2024, 09:14 PM   #56
FlatheadTed
FlatheadTed's Avatar
Nice Work ,I am doing two Cabs my self ,one rusty, one with dents , Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-02-2024, 10:53 AM   #57
Ol' Ron
Ol' Ron's Avatar
Had one of those back in the late 50's, baught it froma guy in NH for 75 dollars and the juce brakes were on it, but didn't work very well. Not sure how I fixed that. It was my dailey driver back then My wife wouldn't allow me to drive her wagon. Wish I never sold it.
Gramps
Old 02-02-2024, 10:59 AM   #58
Ol' Ron
Ol' Ron's Avatar
Memory doesn't work very well either?????
G
