#21 |
Now that it's identified how much oil does it take?
#22 |
All oil pans will fit all engines (8BA). It's the chassis it goes in that determines what it's configuration is.
#23 |
Motor is going into a deuce highboy roadster if I live long enough?
#24 |
Here's the LATE '51 WITHOUT the bracket. ![]() And BELOW is the inside of Gary's (Krylon32) pan with funny dipstick. DD |
#25 |
Both '50 and '51 Merc's have windage trays. Not '49 only.
#26 |
#27 |
#28 |
#29 |
As stated 5qts. is normal but YOU can do some home work to determine if that works with the oil pan/dipstick combination that you have.
This can be done with water before any restoration work.
#30 |
It's a 1953 F100 truck V8 flathead oil pan. One year only.
#31 |
Yes, indeed, this picture of a '53 F100 and the location of the dipstick seem to verify that.
#32 |
Me, I'd put the pan on the assembled engine, mount the engine in the chassis (with full weight), put 5 quarts of oil in it. Then you can see where the level is on the dipstick and mark the dipstick with a blunt chisel.
Now you know exactly where the oil level should be - in your car, at whatever angle it happens to end up in.
#33 |
I thought all truck pans had the big cleanout plate on the bottom?
#34 |
I'm not questioning you guys but the sump on this pan is massive. But if it's from a truck could it possibly hold more than 5 quarts?
#35 |
The '53 truck flathead engines had some unique parts, like the straddle-mounted bell housing, central front engine mount, '49 car-style wide belt water pumps and the full sump oil pan discussed above and correctly identified by '42merc.
#36 |
#37 |
My 53 Merc. EAC has no windage tray but a baffle around the oil pump. That is the part of the pan that is bumped out. Wow there is a lot of different pan configurations out there. Good luck Kube .
