Old 05-13-2021, 09:22 PM   #21
Krylon32
Default Re: Flathead Oil Pan
Now that it's identified how much oil does it take?
Krylon32 is offline   Reply With Quote
Old 05-13-2021, 09:31 PM   #22
tubman
tubman's Avatar
All oil pans will fit all engines (8BA). It's the chassis it goes in that determines what it's configuration is.
Old 05-13-2021, 09:34 PM   #23
Krylon32
Motor is going into a deuce highboy roadster if I live long enough?
Old 05-13-2021, 09:37 PM   #24
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 51 MERC-CT View Post
'51 rear sump without the bracket.
Here's the LATE '51 WITHOUT the bracket.
And BELOW is the inside of Gary's (Krylon32) pan with funny dipstick. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-14-2021, 04:47 AM   #25
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by Tim Ayers View Post
I'm talking about the one with the windage tray. I believe that is '49 Merc only
Both '50 and '51 Merc's have windage trays. Not '49 only.
Old 05-14-2021, 05:02 AM   #26
51 MERC-CT
51 MERC-CT's Avatar
Not necessarily "late" as the MercOmatic pan had no bracket.
Old 05-14-2021, 05:43 AM   #27
Tim Ayers
I think it Should be 5 qts.
Tim Ayers is online now   Reply With Quote
Old 05-14-2021, 05:43 AM   #28
Tim Ayers
Got it. Thanks
Old 05-14-2021, 06:54 AM   #29
51 MERC-CT
51 MERC-CT's Avatar
As stated 5qts. is normal but YOU can do some home work to determine if that works with the oil pan/dipstick combination that you have.
This can be done with water before any restoration work.
Old 05-14-2021, 07:01 AM   #30
42merc
42merc's Avatar
It's a 1953 F100 truck V8 flathead oil pan. One year only.
42merc is offline   Reply With Quote
Old 05-14-2021, 07:38 AM   #31
51 MERC-CT
51 MERC-CT's Avatar
Yes, indeed, this picture of a '53 F100 and the location of the dipstick seem to verify that.
Old 05-14-2021, 10:31 AM   #32
Bored&Stroked
Bored&Stroked's Avatar
Me, I'd put the pan on the assembled engine, mount the engine in the chassis (with full weight), put 5 quarts of oil in it. Then you can see where the level is on the dipstick and mark the dipstick with a blunt chisel.
Now you know exactly where the oil level should be - in your car, at whatever angle it happens to end up in.
Old 05-14-2021, 02:20 PM   #33
Automotive Stud
Automotive Stud's Avatar
I thought all truck pans had the big cleanout plate on the bottom?
Automotive Stud is offline   Reply With Quote
Old 05-14-2021, 02:40 PM   #34
Krylon32
I'm not questioning you guys but the sump on this pan is massive. But if it's from a truck could it possibly hold more than 5 quarts?
Old 05-14-2021, 02:44 PM   #35
V8 Bob
V8 Bob's Avatar
The '53 truck flathead engines had some unique parts, like the straddle-mounted bell housing, central front engine mount, '49 car-style wide belt water pumps and the full sump oil pan discussed above and correctly identified by '42merc.
Old 05-14-2021, 02:52 PM   #36
34PKUP
34PKUP's Avatar
Yes it's possible so just verify as shown in post #29 using your pan and dipstick.
You don't have to mount it on any engine.
34PKUP is offline   Reply With Quote
Old 05-14-2021, 05:31 PM   #37
jimvette59
jimvette59's Avatar
My 53 Merc. EAC has no windage tray but a baffle around the oil pump. That is the part of the pan that is bumped out. Wow there is a lot of different pan configurations out there. Good luck Kube .
jimvette59 is offline   Reply With Quote
