Old 12-18-2017, 07:36 AM   #5
46international
Default Re: Y block flywheel ring gear
Originally Posted by Daves55Sedan View Post
I have a 6-cyl clutch & flywheel with ring gear out in the garage and I have a Ford-O-Matic converter front plate with the ring gear on it. The ring gear for the Ford-O-matic should match closely with what you should have I think. I will try to measure them both.
You mean the Ford-o-matic gear may be able to be cut off and installed on the flywheel? I have a Ford-o in the car now and the ring gear os part of the converter not the flex plate. I would like to get more info on this.
46international is offline   Reply With Quote
