Old 12-06-2016, 09:22 AM   #21
RobR'35
RobR'35's Avatar
Default Re: 59a - or 59ab
How many generations are there for 24 stud block?
RobR'35 is offline   Reply With Quote
Old 12-06-2016, 09:52 AM   #22
37 Coupe
37 Coupe's Avatar
I would say four and this is based on a Jay Temple article in the Jan/Feb 1992 V8 Times. The late '38-40 with the 4 freeze plugs/sand cast plug holes in oil pan rail. 3 1/16 inch bore for Ford 3 3/16 for MercuryNext the 41/42 no freeze plugs and has raised deck where intake bolts.The 46-1948 59 block and then the 49-53 blocks. So that is where I come up with the 4 basics.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 12-06-2016, 10:43 AM   #23
Bruce Lancaster
There is one more, an oddity that has gotten scarce. The first 24 stud used in 1938 had the 81A-A block, quite different from the 81A-B block used in '39 and beyond. This one used the short 68 crank, same as used in '36 LB and 37-8 21 studs, and of course had main saddles to match the 68 type mains. The long crank -B block went into production in very late 1938, and the book (V8 club restoration manual) says that it is unlikely that any went into 1938 cars. To repeat, this is the production '38 24 stud, not the 21 stud also used in '38 and distinct from the '39 24 stud.
Old 12-06-2016, 02:46 PM   #24
papanomad
papanomad's Avatar
seems like the 59 block has 2 varieties 3 1/16 bore and 3 3/16 bore. are there and differences other than bore sizes?
papanomad is offline   Reply With Quote
Old 12-12-2016, 10:35 AM   #25
scooder
Right guys,
I said I'd look at the 59 (only, no letter) block in my stash.
Its a 3 1/16 bore (221 ci) engine.
Has large 59 cast on the bell.
It does indeed pass the pencil test, glad my memory worked this time.
The deck face, it has one triangle top water hole and the two round lower holes, as per a regular 59A, the valve to bore measures like a 59A up, so approx 1.25" further away than the pre war stuff.
The cylinder walls, I don't have a 59A or later block to compare, but much thinner walls than my 99A's. Probably about same as the 221 pre tin can stuff. Don't think it'd comfortably go much over 3 3/16.
So the front of my 59 block is same as pre war stuff, the valve angle and deck face is post war, the cylinder wall thickness looks to be pre war. Pan rail is post war. Has a slinger type crank rather than rope seal.
Like I said it was a mix of stuff.
From this thread it proves even with this limited number produced small bore 59 engines, there's more than one casting style!
Martin.
scooder is offline   Reply With Quote
Old 12-12-2016, 02:17 PM   #26
rotorwrench
rotorwrench's Avatar
Thanks for posting that. This is good information. There are other things that may be possible on these 41A blocks too (big maybe). Most information states that they started production sometime in late 1944 and this always made me wonder if the first ones had the 59 on the bell or not or used the older box & cores. The 59 series (239) production was allowed to start in what would be considered mid year production in 1945. The War Department had eased restrictions with the impending outcome of the war so that the auto manufacturers could get back in to their business and war contracts were being discontinued as surpluses mounted. The 221 blocks continued in production for quite some time after the war as replacement parts.
rotorwrench is online now   Reply With Quote
Old 12-12-2016, 02:50 PM   #27
slowforty
As far as getting heads off I had a friend who made some Heavy Duty hooks that screwed into the spark plug holes. I used two and used a heavy slide hammer (2 lb} on the heads . They came off after a while. Works A Lot better than any other method that i used before. And only had to Curse half as much.
slowforty is offline   Reply With Quote
Old 12-12-2016, 03:03 PM   #28
scooder
The one I have here was from the "matt green" fellows. As in war issue stuff, not sure what it was fitted in, but the flywheel wasn't drilled for a clutch, just had three 3/4" ish holes not far from center.
Martin.
Old 12-12-2016, 05:39 PM   #29
Mart
Mart's Avatar
Mart, I've seen flywheels like that. One keeps coming up on ebay. I wonder if they are marine?? Something like that? Or welder, generator, etc. Some non automotive application.
Mart.
Old 12-12-2016, 06:19 PM   #30
flatford8
flatford8's Avatar
I have one as a stationary engine that I was told powered a water pump. This has a coupler is in the center bolted to the crankshaft but is drilled for a clutch.... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
