Old 12-04-2016, 06:01 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default 59a - or 59ab
Is there any way to tell if a 59A on the heads and block is 3-1/16 or 3-3/16? Just stare at it I guess. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-04-2016, 06:58 PM   #2
papanomad
papanomad's Avatar
Default Re: 59a - or 59ab
pencil test?
papanomad is offline   Reply With Quote
Old 12-04-2016, 07:56 PM   #3
flatjack9
flatjack9's Avatar
Only way is to remove the head and measure the bore.
Old 12-04-2016, 08:03 PM   #4
Flathead
Flathead's Avatar
I never trust what the heads say, most have been swapped around over the years. The only sure thing is that you'll know what the heads are. I know I'm not telling you anything you don't already know Walt
Flathead is offline   Reply With Quote
Old 12-04-2016, 09:36 PM   #5
Walt Dupont--Me.
Originally Posted by papanomad View Post
pencil test?
I never think of pencil test on a 59 block, I've built so many of these things in my many years but I'll I tell when I get the heads. Thanks Walt
Old 12-04-2016, 11:10 PM   #6
rotorwrench
rotorwrench's Avatar
The 41A block (has 59 on bell & was 221 replacement block beginning in 1944) does have characteristics of the prewar 221 engines but I haven't yet studied one to see how close they are. It would be interesting to note these differences.
Old 12-04-2016, 11:13 PM   #7
GB SISSON
GB SISSON's Avatar
I have a block on my stand that's '59' and 221 cu in, 3 1/16. Heads are still off. I could get good pics if I knew what to shoot or measure.
Old 12-05-2016, 08:36 AM   #8
Walt Dupont--Me.
This engine I just started on 59 on the bell and 59AB on the heads, a rebuild tag on the back built by shop in Boston Mass. I'm sure it's oversize, I have got about half doz of those tags kicking around the back of my bench, the heads stuck pretty hard,been socking, trying to get them off today, let you know, Walt
Old 12-05-2016, 08:44 AM   #9
scooder
Walt,
The small bore 59's pass the pencil test, not seen one that didn't pass.
Martin.
scooder is offline   Reply With Quote
Old 12-05-2016, 01:54 PM   #10
Walt Dupont--Me.
Originally Posted by scooder View Post
Walt,
Martin.
Well guys I got the stuck heads off this 59 block, 3-3/16 + .030 it won't hold a pencil, so it's just a 59AB block with 59A heads, 46-47-48 crab dis. So I'll check pencil from now on, never know if anyone has changed heads. So if it holds the pencil test chances are it's a 3-1/16 or something, What if it was bored 3-3/16 and cain't tell? Then you go and bore another 1/8, dose anyone know if the walls are the same thickness? chances are there all the same block and the factory bored some 3-1/16 cause they had alot pistons left over. Walt
Old 12-05-2016, 02:24 PM   #11
rotorwrench
I'd sure like to see one of the 41A blocks so I could be sure for my own information but some folks say they are very much like the prewar 221 blocks and have thin cylinder walls like they were using the prewar cores in the post war core box. I hope someone comes up with one to photograph for the block ID thread some day. It would be nice to know what all the true characteristics are.
Old 12-05-2016, 04:00 PM   #12
GB SISSON
GB SISSON's Avatar
OK, so what's the pencil test?
Old 12-05-2016, 04:28 PM   #13
Cecil/WV
Cecil/WV's Avatar
Its my understanding that if a pencil will lay on the block just above the timing cover that its a '40 221 block. I have one in my stack.
Cecil/WV is offline   Reply With Quote
Old 12-05-2016, 06:07 PM   #14
rotorwrench
That's what it is. The post war engines had a different design on the front of the block so there is no pronounced flange there for the timing cover. The timing cover itself it all that protrudes there. Prewar engines had a bit of flange protrusion making for a pretty good step in that location.
Old 12-05-2016, 08:38 PM   #15
Walt Dupont--Me.
An other difference, I built a 59 engine a couple years ago for a 35 pickup, it had a rear oil slinger rather than a rope seal. I used an 8BA crank and rods with the 59 aluminum seal. Never so that before. Walt
Old 12-05-2016, 09:24 PM   #16
38bill
38bill's Avatar
My 59AB had a oil slinger too. Found that out when I pulled it out of the pickup and it poured oil out the back end. At the time it seemed it would be easier to drain the oil with the engine on the lift, who knew. We just figured it had a previous Frankenstein type rebuild because of all the miss matched parts we found.
38bill is offline   Reply With Quote
Old 12-05-2016, 10:01 PM   #17
GB SISSON
GB SISSON's Avatar
Just went down to the shop and looked at the timing cover area. There is no way a pencil could sit there if the timing cover wasn't on. It just slopes down to nothing. The bell housing has a '59' cast on top. Don't recall what the cyl heads were, but it's 3 1/16 for sure... .060 over. Has a tag from rebuilder ford authorized which reflects the specs of the engine. Not sure if that helps.....
Old 12-06-2016, 08:19 AM   #18
Bored&Stroked
Bored&Stroked's Avatar
I've not seen any blocks with just 59 on the bell housing that passed the pencil test - only the early blocks (pre-war). I'm not saying they don't exist - just never seen one.
Usually when a see a block with just the 59 on the bell, my hunch is that it will be a 3 1/16 bore block (replacement) - just the way I've seen most of them over the years.
Old 12-06-2016, 08:33 AM   #19
scooder
Gonna have to check the 59 block I have stashed, my reply about the pencil test was from memory, so could be bolox. It is a mish mash of pre and post war casting box's.
I'll check and report back.
Martin.
Old 12-06-2016, 09:00 AM   #20
37 Coupe
37 Coupe's Avatar
The pencil test is to exclude the 59 block not to confirm it.The pencil test works on the first generation 24 stud blocks,late '38,39 and 40 41.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
