#1 | |
Hey there. A few weeks ago, OldWhizzer here on the Barn posted a thread asking about an unusual Model A Carb. I was fascinated to see it, and especially when Ray In La Mesa brought up the fact that it looked like the experimental Holly carb that Vince Falter wrote about on fordgarage.com. This really sparked my curiosity about the carb.
![]() Fast forward a few days and I saw the carb on eBay. This is the kind of strange Model A stuff that gets me excited, so I placed my bid and won it. OldWhizzer packed it really well and I was happy it arrived safely. It wasn't out of the box for more than 5 minutes before I had it laid out in pieces on my desk here at work snapping pictures to share with you guys. ![]() ![]() Quote:
Here are a few pics of my carburetor. ![]() ![]() A few other observations were the welded vented screen on the bottom, but how nicely it was finished on the outside. ![]() ![]() Also, the GAV is brazed inside the bowl, but also finished very nicely on the outside. ![]() ![]() I believe that my carb may have been a one off test carburetor for visual inspection due to the high quality of exterior finish, and there is a faint smell of gas and oily residue at the bottom of the vented screen, so it was also run on an engine at one time. It may also be a slightly earlier variation on the once Vince pictured because of the fact that there is no sign of a name badge ever being mounted on mine, only the numbers on the top, and the fact that the vented screen on the bottom is SO hard to remove that the design was done away with, requiring the bailing wire to be rethought into the tabbed wings on the bowl. ![]() I have not yet tried to run the carburetor because the brittle cork gasket around the bowl broke when I took it apart. I would ultimately love to take this by Dennis Piranio's shop and have him put it on the dyno to get more performance information about it. Please review the additional photos below, and I look forward to the discussion that this thread brings.
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 11-29-2010 at 03:03 PM. |
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 11-29-2010 at 01:16 PM. |
Very nice , THANK YOU ! for the pictures... its really neat.
I also think it's neat.
What are your plans for it? Are you going to try and use it? |
Thanks! I'm excited about it as well.
Yes. I would like to replace the two cork gaskets and try it out to see if it gets better gas mileage or more performance. Is there a site where you can order your defined ID / OD neoprene gaskets, or should I try to carefully make my own rings with some cork and an exacto knife?
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
That is really interesting! Good luck getting it to run and be sure to let us know how it works out. It looks a lot simplier than a Zenith......
My only question is, would a prototype have a patent tag on it?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
Very interesting, I would try O-rings, it looks like the thickness is important, there seems to be seals on 2 jets by the GAV boss --not having leakage there could be important.
If you know someone that rebuilds auto transmissions see if they have a "leftover o-ring/seal box", that would have many choices , plumbing supply stores usually have good assortments, also hydraulic hose--jack repair places. |
That is SO COOL! Glad I could send you in the right direction. Let us know how it runs.
#12 | |
![]() Quote:
buying tubing and sanding/filing to have a sharp edge is also an option if necissary thanks for all the pics Zach
-WANTED-
CYLINDER HEADS 77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS |
#13 | |
![]() Quote:
Great idea Zach. A fellow THEM! member here owns a machine shop, but I may go the O-Ring route and see if anything exists before tying up one of his machines.
#14 |
This great post got me to thinking about an unusual (at least to me) carb in my garage ... many characteristics of a Zenith but has a brass "Simmons" tag riveted on top ... no where near as interesting as the one above but i would appreciate any info anyone has to offer.
#15 |
Kind of looks like a fore-runner of the Holley "Centri-Flow" that would be used on Ford - Merc - Lincoln V-8s in the early 1950's...
Neat carb; thanks for all the pics ! |
#16 |
Hey Charles - Cool Carburetor. The Simmons Carburetor company was known for building "better performance" carburetors and also a Simmons Super Power cylinder head for the Model T crowd. I can only read the 1st patent on your carburetor, and the following link is the patent information for your carburetor. http://www.freepatentsonline.com/1584759.pdf
I found this discussion about the Simmons Carburetor Company, and one person claims they re-branded these as "The Wizzard" and sold them at Western Auto. http://www.mtfca.com/discus/messages...tml?1289869004 Now, your carburetor is clearly a Model A carb due to the GAV adjustment, so probably an aftermarket carburetor designed for a little better performance. Simmons may have established themselves with the Model T owners which saw lots of after market parts for their cars, and attempted to move into the Model A arena in the aftermarket segment. Who knows, maybe that is what my Holley carb was also.
#17 |
Hi Charles
Running your patent numbers thru Google or the USPTO should give you the inventor and some filing/issue date info. The tag in your photo is hard to read, but the first # appears to be 1584759, but I could not read the second tag number. George A. Eynon Parma Heights, Ohio Carburetor Patent number: 1584759 Filing date: Mar 14, 1925 Issue date: May 18, 1926 http://tinyurl.com/2bj8y28 Regards Art |
#18 |
might this then be a "T" item? I note that the bowl has a fitting unlike the "A" style i am familiar with. seems someone with a Simmons cylinder head might have a better use for it than I do. open to offers/swap.
