Old 11-29-2010, 12:41 PM   #1
Jason in TX
Jason in TX's Avatar
Default A Rare Holley Prototype Carb? - Lots of Photos
Hey there. A few weeks ago, OldWhizzer here on the Barn posted a thread asking about an unusual Model A Carb. I was fascinated to see it, and especially when Ray In La Mesa brought up the fact that it looked like the experimental Holly carb that Vince Falter wrote about on fordgarage.com. This really sparked my curiosity about the carb.
Fast forward a few days and I saw the carb on eBay. This is the kind of strange Model A stuff that gets me excited, so I placed my bid and won it. OldWhizzer packed it really well and I was happy it arrived safely. It wasn't out of the box for more than 5 minutes before I had it laid out in pieces on my desk here at work snapping pictures to share with you guys.
Here is a link to Vince Falter's Ford Garage article from Feb 2001 about what he believes to be an experimental Holley Carb that never went into production for the Model A. http://www.fordgarage.com/pages/holleycarb.htm
He states that his carburetor came from one of the Henry Ford Museum & Greenfield Village property dispersal auctions in the late 1980s and he speculates that it may have been a prototype carburetor that never went into production.
On his carburetor is the patent number 1,742,376 which shows a carburetor unlike the one pictured, but that the patent number was granted on Jan 7th of 1930, so his carburetor must date later than that since the tag holds that number rather than saying Patent Pending.
Here is Vince's carburetor. More photos at his link.
Upon internal examination of the carburetor I just purchased, it is apparent that this one I just purchased was made by the same manufacturer. Internally, the needle adjustment valve, bowl shape, brass float, venturi tube, the white felt gaskets used, etc appear to be exactly like the Holley 440 carburetor pictured on Vince's page. Externally, my carburetor is held together by the bailing wire, and the vented cover on the bottom was difficult to remove because of the choke shaft sticking through the hole causing interference.
Here are a few pics of my carburetor.
A few other observations were the welded vented screen on the bottom, but how nicely it was finished on the outside.
Also, the GAV is brazed inside the bowl, but also finished very nicely on the outside.
I believe that my carb may have been a one off test carburetor for visual inspection due to the high quality of exterior finish, and there is a faint smell of gas and oily residue at the bottom of the vented screen, so it was also run on an engine at one time.
It may also be a slightly earlier variation on the once Vince pictured because of the fact that there is no sign of a name badge ever being mounted on mine, only the numbers on the top, and the fact that the vented screen on the bottom is SO hard to remove that the design was done away with, requiring the bailing wire to be rethought into the tabbed wings on the bowl.
I have not yet tried to run the carburetor because the brittle cork gasket around the bowl broke when I took it apart. I would ultimately love to take this by Dennis Piranio's shop and have him put it on the dyno to get more performance information about it.
Please review the additional photos below, and I look forward to the discussion that this thread brings.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 11-29-2010, 12:41 PM   #2
Jason in TX
Default Re: Another Rare Holley Prototype Carb? - Lots of Photos
Old 11-29-2010, 05:53 PM   #3
peters180a/170b
peters180a/170b's Avatar
Default Re: A Rare Holley Prototype Carb? - Lots of Photos
Very nice , THANK YOU ! for the pictures... its really neat.
peters180a/170b is offline   Reply With Quote
Old 11-29-2010, 05:55 PM   #4
Blessyouboys
Blessyouboys's Avatar
I also think it's neat.
What are your plans for it? Are you going to try and use it?
Blessyouboys is offline   Reply With Quote
Old 11-29-2010, 05:58 PM   #5
Jason in TX
Thanks! I'm excited about it as well.
Yes. I would like to replace the two cork gaskets and try it out to see if it gets better gas mileage or more performance.
Is there a site where you can order your defined ID / OD neoprene gaskets, or should I try to carefully make my own rings with some cork and an exacto knife?
Old 11-29-2010, 06:31 PM   #6
John Stone
John Stone's Avatar
You might try McMaster-Carr.
John Stone is offline   Reply With Quote
Old 11-29-2010, 10:14 PM   #7
Jim Parker Toronto
Jim Parker Toronto's Avatar
That is really interesting! Good luck getting it to run and be sure to let us know how it works out. It looks a lot simplier than a Zenith......
Jim Parker Toronto is offline   Reply With Quote
Old 11-29-2010, 10:28 PM   #8
Chris Haynes
Chris Haynes's Avatar
My only question is, would a prototype have a patent tag on it?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-29-2010, 11:42 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Very interesting, I would try O-rings, it looks like the thickness is important, there seems to be seals on 2 jets by the GAV boss --not having leakage there could be important.
If you know someone that rebuilds auto transmissions see if they have a "leftover o-ring/seal box", that would have many choices , plumbing supply stores usually have good assortments, also hydraulic hose--jack repair places.
Old 11-30-2010, 10:07 AM   #10
Ray in La Mesa
That is SO COOL! Glad I could send you in the right direction. Let us know how it runs.
Ray in La Mesa is offline   Reply With Quote
Old 11-30-2010, 10:24 AM   #11
MrTube
MrTube's Avatar
Absolutely.
Many things were and are patented that are never even built.
MrTube is offline   Reply With Quote
Old 11-30-2010, 10:56 AM   #12
SUHRsc
SUHRsc's Avatar
if you have access to a lathe... making a sharpened round tool to punch out any size you want wouldnt be much work...
buying tubing and sanding/filing to have a sharp edge is also an option if necissary
thanks for all the pics
Zach
-WANTED-
CYLINDER HEADS
77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS
SUHRsc is offline   Reply With Quote
Old 11-30-2010, 11:10 AM   #13
Jason in TX
GOOD POINT! Makes total sense since there are small felt "gaskets" at the tops of those jets. My mind was so focused on solving the perimeter gasket issue, I forgot to consider how it would affect the internals. Thanks for bringing that up Kurt before going through the trouble to make something too thick and then it not working.
Originally Posted by SUHRsc View Post
if you have access to a lathe... making a sharpened round tool to punch out any size you want wouldnt be much work...Zach
Great idea Zach. A fellow THEM! member here owns a machine shop, but I may go the O-Ring route and see if anything exists before tying up one of his machines.
Old 11-30-2010, 11:54 AM   #14
Charles Reese
Charles Reese's Avatar
This great post got me to thinking about an unusual (at least to me) carb in my garage ... many characteristics of a Zenith but has a brass "Simmons" tag riveted on top ... no where near as interesting as the one above but i would appreciate any info anyone has to offer.
Charles Reese is offline   Reply With Quote
Old 11-30-2010, 01:11 PM   #15
Special Coupe Frank
Special Coupe Frank's Avatar
Kind of looks like a fore-runner of the Holley "Centri-Flow" that would be used on Ford - Merc - Lincoln V-8s in the early 1950's...
Neat carb; thanks for all the pics !
Special Coupe Frank is offline   Reply With Quote
Old 11-30-2010, 01:20 PM   #16
Jason in TX
Hey Charles - Cool Carburetor. The Simmons Carburetor company was known for building "better performance" carburetors and also a Simmons Super Power cylinder head for the Model T crowd. I can only read the 1st patent on your carburetor, and the following link is the patent information for your carburetor. http://www.freepatentsonline.com/1584759.pdf
I found this discussion about the Simmons Carburetor Company, and one person claims they re-branded these as "The Wizzard" and sold them at Western Auto.
http://www.mtfca.com/discus/messages...tml?1289869004
Now, your carburetor is clearly a Model A carb due to the GAV adjustment, so probably an aftermarket carburetor designed for a little better performance.
Simmons may have established themselves with the Model T owners which saw lots of after market parts for their cars, and attempted to move into the Model A arena in the aftermarket segment.
Who knows, maybe that is what my Holley carb was also.
Old 11-30-2010, 03:16 PM   #17
Mustang
Mustang's Avatar
Hi Charles
Running your patent numbers thru Google or the USPTO
should give you the inventor and some filing/issue date info.
The tag in your photo is hard to read, but the first # appears
to be 1584759, but I could not read the second tag number.
George A. Eynon
Parma Heights, Ohio
Carburetor
Patent number: 1584759
Filing date: Mar 14, 1925
Issue date: May 18, 1926
http://tinyurl.com/2bj8y28
Regards
Art
Mustang is offline   Reply With Quote
Old 11-30-2010, 08:09 PM   #18
Charles Reese
might this then be a "T" item? I note that the bowl has a fitting unlike the "A" style i am familiar with. seems someone with a Simmons cylinder head might have a better use for it than I do. open to offers/swap.
