Tom,
I recently went through this. The only 1 1/16" mc I found was from Wilwood. Unfortunately, it just didn't move enough fluid to work correctly and I ended up using a 1 1/8" one from Summit. When I say 'correctly', I spent a lot of time studying how a mc works and what is SUPPOSED to happen if one circuit fails. So, while the 1 1/6" mc worked OK under normal circumstances, it would NOT work in the event of a failure of either front or rear brakes. There was just not enough pedal travel in my '36. IMO, I think the 1 1/8" one works great. The pedal effort/travel is fine for me. But Mart is correct. Plumbing is a nightmare all to itself. I spent a lot of time on the Net and at the local parts houses trying to get all the fittings I needed. It was not fun. Heard
Do I look like I have a plan B? |
