Old 01-08-2015, 10:07 AM   #2
TJ
TJ's Avatar
Default Re: Master cylinder conversion
I'm not sure you can find a dual MC with the 1 1/16 bore. They do make an adapter that goes from 3 bolt to 2 bolt for the 39 pedal assemble ,so you can use the dual MC. It moves the MC back about 3/4". There are adapters that will screw into the MC that will allow the 1/4" lines. Some dual cylinders have residual valves and some do not. It would take some research and a parts house with some knowledgeable people willing to help to find a cylinder with the correct specifications to use with the adapter.
TJ is online now   Reply With Quote
