Need a place to send rods to get reconditioned, oba-6200 52 to 53 motor ?
thanks kurt |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
You can send them to us.
We can rebuild them with new ARP nuts and new wrist pin bushings and even weight match them if you want? https://www.jandm-machine.com/ |
My local machine shop does them, has done many sets for me. Schmidt Machine, Fairbury NE.
Hey J&M, how do you balance the big-ends? Where do you remove material from? Also, how do you install the pin bushings . . do you swage them in like Ford did?
#5 | |
Typical set of V8 rods are usually within 6 grams as long as they haven't been swapped out. Yes we have a tool prior to honing the wrist pin bushings that forces the bushing tightly against the rod prior to final honing. |
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
#7 | |
And here I thought that another valuable asset just came forward. Oh well. The guy at the local (Brainerd, MN) NAPA machine shop did mine for one hell of a lot less than that. "Shoebox", I see you live in rural Wisconsin; check and see if here is a shop near you that does tractors, etc. If a guy can do an 8N or 9N, a flathead would be a natural. |
Sorry, duplicate post.
#9 | |
We don't sell parts as you can get them from Speedway or Summitracing. |
You can buy the H-beams from CNC-Motorsports for about $650:
https://cnc-motorsports.com/2-239-70...ting-rods.html |
#12 | |
Sounds like you have the correct "swaging" tool for the bushings - that is good to know. I made a fixture for my lathe to hold the cap - works great. Here are some pics: 2015-02-07 19.33.56 copy.jpg 2015-02-02 21.34.39 copy.jpg 2015-02-10 13.16.06 copy.jpg |
#13 |
On my website I sell OBA-6211 rods with the hole for bearing which is different than the 8 BA6200 for with no hole. Exact replacement 50-53. They are $36.00 each plus postage
#14 |
I would take up Barnfind08 on his parts and buy a NOS from him!
#15 |
Already done.
#16 |
Fred had/has NOS French rods I believe.
#17 | |
I just did!
#18 |
Where’s your website
#19 |
