Old 12-06-2012, 06:39 PM   #1
Beau Dirt
Default 35/36 Ford aftermarket tube shock mounts 1935 1936
A friend and I each picked up sets of the clamp on tube shock mounts for the 35/36 rear radius rods.
Any info on them and if they are worth using?
Thanks.
Beau Dirt is offline   Reply With Quote
Old 12-06-2012, 07:19 PM   #2
Don
Don's Avatar
Default Re: 35/36 aftermarket tube shock mounts
This is what I am using on my 36 5 w,the way I see it I can't fit upper mount till I get the body back on.I don't see why they won't work. There is a rt and left
DON P
Don is offline   Reply With Quote
Old 12-06-2012, 07:34 PM   #3
Beau Dirt
Thanks! Any idea who made them?
I have not had a chance to see how they fit. I'm gonna soak them in vinegar for a few days and try to get them apart.
If you happen to have any photos of how they mount that would be great.
Beau
Old 12-06-2012, 10:21 PM   #4
jfcrash
jfcrash's Avatar
I had a pair of those shock brackets on my 35 Phaeton which I removed during restoration.
Below are two photos, one showing the assembly bolted to the LH radius rod. In the second photo, the bolt at the top of the tube shock came through the frame and bracket on the right...someone must have cut away the inner fender to accept the mtg hardware.
Hopes this helps.
Jim
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 01-12-2013, 11:25 PM   #5
Beau Dirt
Well, after a year I finally stumbled upon what they are. My buddy Jay, who bought a set, had the picture in a thread he started a few years back. Ironic.
It's a Houdaille tube shock conversion kit.
Old 01-21-2013, 11:55 PM   #6
Beau Dirt
Here are some photos after I cleaned it all up.
They won't work on my car because of the angle I'm running the rods at.
They will go to a fellow Ford Barn Member from CA to re-energize his motivation to complete his build.
Hopefully this thread will help others out.
14658- R
14659- L
Old 06-18-2017, 07:16 PM   #7
MIKEV3550
MIKEV3550's Avatar
Does anyone know what brand/ size shock would fit this set up ?
MIKEV3550 is offline   Reply With Quote
Old 06-18-2017, 09:28 PM   #8
johndee138
johndee138's Avatar
I have this setup and a new pair of Gabriel shocks for it. Not installed yet. The Car is in a shop across town so I cant get to the box to give you the part numbers but if I remember correctly they corresponded with 46-7 rear tube type. When I get back to the shop I'll note the part # and post it to you.
johndee138 is offline   Reply With Quote
Old 06-19-2017, 05:55 AM   #9
MIKEV3550
MIKEV3550's Avatar
Thanks John, let me know when you get the part number... really appreciate it..
Old 06-19-2017, 07:49 AM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
Good information! Did not know these adapters were made by Houdaille. Have a set like these on a '35 3w coupe that was probably built back in the '60's. Looking forward to seeing info from "johndee" on brand and part number of shocks that would be used with these aftermarket rear shock mount brackets/adapters.
John
Old 06-21-2017, 07:21 PM   #11
Matt in Alameda
Hey Johndee.......please don't forget to publish the part # for the shocks......Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 06-27-2017, 12:08 PM   #12
johndee138
johndee138's Avatar
Gabriel Classic gas shock #82007 is the one.
I think I got them at Amazon but many sellers carry them. I looked for the cheapest one, of course!
Old 06-27-2017, 07:22 PM   #13
MIKEV3550
MIKEV3550's Avatar
Smile Re: 35/36 aftermarket tube shock mounts
Thanks John.. That info saves a lot of time in trying to find out what shocks would fit that application... Mike..
