#1 |
Can anyone tell me what a cast iron puller with KMODET over T204 cast on the side of it pulled. The body is 2 1/4" in dia. with one side left open to receive whatever is being pulled. Bottom has a one inch open slot to receive whatever is being removed from larger part above. Top is a solid hub with a 1/2" bolt tapped through it to push something through the part inside main body. Hex on bolt is 3/4" with hole through hex for a sliding rod handle. I cannot come up with good use for it. Thanks
#2 |
Sounds like a rear Model A hub puller,just guessing,without a picture.
#3 |
model A on top or model T wire wheel hubs below... ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!" |
#4 |
Sorry cannot send picture because of no digital camera and not knowledge of finer points of computers. I must guess that it's not a hub puller because a 1" slot will not go over any model A hub I've ever seen ant the reach of 1 3/8" is too short. Could it be a generator drive gear puller? Just a guess cause I'm a model A person.
#5 |
Could be a Bendix puller. Sounds about the right size.
#6 |
