Old 12-03-2012, 04:29 PM   #1
Keith
Default When Timing Dist. which direction advances the timing
I am having a brain fart this afternoon. When timing a Model A which direction do you move the rotor to advance the timing?
The rotor turns counter clockwise when the engining is running so the question is when loosening the cam screw which direction do you turn the rotor to advance the timing.?
Keith
Keith is offline   Reply With Quote
Old 12-03-2012, 04:33 PM   #2
Gord. B by the bay
Default Re: When Timing Dist. which direction advances the timing
Counter Clockwise Gord. B
Gord. B by the bay is offline   Reply With Quote
Old 12-04-2012, 12:42 AM   #3
ctlikon0712
ctlikon0712's Avatar
Is this a stock distributor that is pined in place by the head, or an aftermarket one that you turn and clamp down? The reason I ask is that you advance and retard the distributor cam to change the timing not the rotor in a original dissy.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 12-04-2012, 08:04 AM   #4
Keith
This is set up as a standard factory dist.
So to confirm, Counter Clockwise to advance
Clockwise to retard.
Thanks,
Keith
Old 12-04-2012, 09:14 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Thanks,
Correct, and after setting the timing and tightening the cam screw be sure to apply pressure in the clockwise position to take up the freeplay to make the most accurate final adjustment. Since the advance lever allows 40* advance, which is more than the Model A needs, I don't think being off a couple degrees on initial timing is a big , but I still try to be accurate.
Old 12-04-2012, 10:18 AM   #6
Marco Tahtaras
Marco Tahtaras's Avatar
Check out this link:
Model 'A' Ignition Timing
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
