Old 09-25-2012, 02:38 PM   #1
springerpete
springerpete's Avatar
Default slippery wind wings
Almost 1000 miles on my 29 since I got it and now I am having trouble keeping the wind wing glass in the clamps. I have been thru the re-clamo process 3 times now.
I find the knurled screw fittings to be of poor quality. They jam easily in their threaded holes so it is not easy to get the clamps tight before you tighten the screw. Maybe I've got it OK now, the 3rd time, but I'd be interested to know how those of you have solved this problem. Yes, the metal fittings are brand new a month ago.
springerpete is offline   Reply With Quote
Old 09-25-2012, 02:47 PM   #2
Bruce
Bruce's Avatar
Default Re: slippery wind wings
Passing on a tip from Phred: Try a dab of silicone glue-caulk. Buy the tube that says it is for metal and glass. Then, hold it -- or use masking tape to hold it in place while the bond sets up.
Bruce is offline   Reply With Quote
Old 09-25-2012, 03:27 PM   #3
peters180a/170b
peters180a/170b's Avatar
Go to a Auto glass business and buy a tube of black glue.. you must heat it up with a heat gun or a very good hair dryer. 3 years and not a thin hair of movement !!!! Once that shit is on...its on....
peters180a/170b is offline   Reply With Quote
Old 09-25-2012, 04:00 PM   #4
RHD
RHD's Avatar
Iv'e used double sided industrial tape. It works 100%. Just cut the tape carefully around the clamp.
R.H.D.
Silence is golden unless you have kids, then silence is suspicious.
RHD is offline   Reply With Quote
Old 09-25-2012, 04:34 PM   #5
springerpete
Thanks, guys for the good suggestions. Busy tomorrow but I'll get at it again on Thursday.
Old 09-25-2012, 04:48 PM   #6
Larry Seemann
"3M Permanent Mounting Tape" is a 2 sided tape that has worked well for me for several years.
Larry Seemann
Larry Seemann is offline   Reply With Quote
Old 09-25-2012, 05:01 PM   #7
Great Lakes Greg
Great Lakes Greg's Avatar
The stuff Larry mentions is what I used. Extremely sticky. I believe it is supposed to hold the plastic mouldings on the outside of cars.
Great Lakes Greg is offline   Reply With Quote
Old 09-25-2012, 05:21 PM   #8
Bruce,Upstate NY
There is a special glue for attaching modern mirror brackets to the inside of windshields.
Bruce,Upstate NY is offline   Reply With Quote
Old 09-25-2012, 05:43 PM   #9
Michael in Sedona
Michael in Sedona's Avatar
I'll second the double-sided tape idea. My windwings almost came off twice, then I tried the tape and no problems since.
Michael in Sedona is offline   Reply With Quote
Old 09-26-2012, 09:10 AM   #10
Marklambert61
Marklambert61's Avatar
I cut a small pocket in the fixed side of the clamp and installed an O-ring.
Seems to have work great can't tell it was ever modified after re-assembly.
Mark
Marklambert61 is offline   Reply With Quote
Old 09-26-2012, 10:15 AM   #11
oldrelics
Lightly sandblast the areas on the glass might be an idea.
oldrelics is offline   Reply With Quote
