Old 07-02-2012, 05:58 AM   #1
johnbuckley
johnbuckley's Avatar
Default Sticking starter swtich
The contact in the starter switch sometimes seems to weld itself to the button on the motor. Any suggestions?
johnbuckley is offline   Reply With Quote
Old 07-02-2012, 07:07 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Sticking starter swtich
I dissassemble the switch and resurface the contact points. If the bronze plate has any cracks at the bolt hole, discard that part. Gar Williams
Aerocraft is offline   Reply With Quote
Old 07-02-2012, 07:28 AM   #3
Sparky
Sparky's Avatar
What Gar said above, also I had good results from bending the spring contact slightly "away" from the stud on the starter.
Sparky is offline   Reply With Quote
Old 07-02-2012, 02:27 PM   #4
Michael in Sedona
Michael in Sedona's Avatar
I've done the same thing as Sparky said. The spring seems to get weaker over time, and now and then needs to be bent back a little.
Michael in Sedona is offline   Reply With Quote
Old 07-02-2012, 02:41 PM   #5
Will N
Will N's Avatar
I've added a small section of rubber hose under the copper (I have a repro switch) contact spring in order to give it a more of a push upward when released.
Will N is offline   Reply With Quote
Old 07-03-2012, 10:46 AM   #6
Farrell In Vancouver
Farrell In Vancouver's Avatar
Low voltage supply will cause this too. Make sure the battery, and grounds are up to snuff.
Farrell In Vancouver is offline   Reply With Quote
Old 07-03-2012, 05:24 PM   #7
Muttley
Muttley's Avatar
Had the same problem on my Dad's Coupe, we decided to get rid of the floor switch and wire in a button/solenoid........it was a huge improvement.
Muttley is offline   Reply With Quote
Old 07-04-2012, 10:32 PM   #8
columbiA
Also make sure the starter is in good shape & not drawing to much current.Also if starter,switch and wiring are up to snuff,no solenoid needed.
columbiA is offline   Reply With Quote
Old 07-05-2012, 08:09 PM   #9
sphanna
sphanna's Avatar
I did what Will N did and it works great.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 07-05-2012, 08:27 PM   #10
Clem Clement
Clem Clement's Avatar
Some of the cheapo repro starter switches have bronze or poor grade of copper for the contact arm. This will heat up and lose its springeness.
Clem Clement is offline   Reply With Quote
Old 07-05-2012, 10:06 PM   #11
tbirdtbird
"This will heat up and lose its springiness." This will also happen if the starter is engaged for long periods trying to start a stubborn motor or one that needs service
'31 180A
tbirdtbird is offline   Reply With Quote
