Old 05-24-2012, 09:49 AM   #1
tomrobson
Default 1927rear hubs
how do you seperate the hub and drum?
tomrobson is offline   Reply With Quote
Old 05-24-2012, 10:38 AM   #2
Farmallcub49
Farmallcub49's Avatar
Default Re: 1927rear hubs
Remove the hub nuts and bolts and the hub should come free of the drum. They may be rusted together, so some heat would be of help or some sort of penetrant oil.
'OSO HANDY RESTORATIONS
Specializing in Model T Fords
320-293-1953
Farmallcub49 is offline   Reply With Quote
Old 05-24-2012, 02:21 PM   #3
yachtsmanbill
yachtsmanbill's Avatar
Wood or wire wheels? Wood ones drive the bolts all out. Replace with new ones!!! Wire wheel hubs have a stud thats swaged into the drum. Have a motor parts with a press do those. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 05-25-2012, 03:34 PM   #4
tomrobson
thank you sir . these are steel spoke rims and the studs seem to be welded to thehub I was thinking maybe I could press the center of the hub through the drum but I was wondering what would happen to the bolts?
Old 05-25-2012, 04:27 PM   #5
tmodelman
If front hub, the long nose of the front hub fits snug to the taper snout of the Ford T wire wheel center, you have to use lots of good penetrating oil (WD-40 is not a penetrating oil) or heat if really rust stuck from years.
Press on the hub with the wheel supported, the lug bolts are swaged in the front hubs, the rear hubs are usually keyed with upturned metal lug on the rear drum inside. Over the years some owner may have welded the lug bolts in the hubs as easy fix, but terrible for replacing the lug bolts
tmodelman is offline   Reply With Quote
