Old 04-22-2012, 09:37 PM   #1
Init1
Init1's Avatar
Default hot water shut off valve
Anybody found a source for angled hot water shut valves for flathead?
Seems they don't exist. Just the 90 degree type.
Init1 is offline   Reply With Quote
Old 04-23-2012, 06:46 AM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: hot water shut off valve
Found this on Google: http://antique-auto-parts.com/zencar...lve-p-303.html
4dFord/SC is offline   Reply With Quote
Old 04-23-2012, 04:45 PM   #3
Ian NZ
Ian NZ's Avatar
The original hot water heater valve that screws into the cylinder head hose fitting comes out at a 45D angle
Ian NZ is offline   Reply With Quote
Old 02-05-2017, 07:36 PM   #4
1948F-1Pickup
1948F-1Pickup's Avatar
Old thread and nobody's probably looking but
these are the 45-degree style. (Four Seasons
84790)
http://www.opticatonline.com/part/fo...heater-fitting
1948F-1Pickup is offline   Reply With Quote
Old 02-05-2017, 07:51 PM   #5
paul2748
paul2748's Avatar
If your looking for a heater/water valve, just go to ebay and put in heater valve. All sorts of different valves.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-05-2017, 08:56 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
What year you referring to?? I know the correct ones for 39&40 are 90 degrees but the valve that you turn is on a horizontal plane and not vertical like the repops are made.
Ken/Alabama is offline   Reply With Quote
Old 02-05-2017, 10:42 PM   #7
Newc
Newc's Avatar
Hi all; : Note that the valve and stem of the modern NAPA part will fit the original valve body and make it work. The seat in the originals is usually good. Curiously, I've notice a lot of Junk engines still have these in their heads. Newc
Old 02-06-2017, 11:42 AM   #8
19Fordy
19Fordy's Avatar
4dFord/SC: The site you posted comes out in a foreign language. Is it a Zen thing?
Old 02-06-2017, 12:09 PM   #9
54vicky
54vicky's Avatar
Wink Re: hot water shut off valve
I am pretty sure he realizes that by now.if not after 4 years he may not care.people should look more closely at date of postings before replying.
54vicky is offline   Reply With Quote
Old 02-06-2017, 09:41 PM   #10
Highboy34
Balkamp made one which I found on ebay.
Highboy34 is offline   Reply With Quote
Old 02-07-2017, 08:47 AM   #11
JSeery
JSeery's Avatar
Anyone have some photos of different original valves?
