Old 03-23-2012, 03:01 PM   #1
1pieceatatime
Default brake woes!
i have a 58 ford custom 300. i have put the body on a 1990 crown victoria chassis and shoved in a 406. my problem now is that i cant fit a power booster in because the valve cover is in the way. i tried an 8" booster from a ford ranger but its to big. does anyone know of any thing that uses a booster thats smaller than 7"?
1pieceatatime is offline   Reply With Quote
Old 03-23-2012, 04:48 PM   #2
Ole Don
Ole Don's Avatar
Default Re: brake woes!
A big block Torino used a bracket that raised the booster about six inches. They were very hard to find, now avaiable in the Speedway catalogue for just under fifty bucks.
Ole Don is offline   Reply With Quote
Old 03-23-2012, 05:35 PM   #3
1pieceatatime
thanks for the tip but i also dont have any more room above where it mounts to the fire wall because its so close to the hood now. ive tried just about everything i can think of and nothing works out except a smaller booster or no power brakes!
Old 03-23-2012, 06:29 PM   #4
tdlmomowers
tdlmomowers's Avatar
What about a Hydro Boost unit? I know they are smaller than most vacumn boosters. Maybe you don't have a power steering pump to run a hydro boost. Just a thought.
tdlmomowers is offline   Reply With Quote
Old 03-23-2012, 07:54 PM   #5
Frankenstein57
Frankenstein57's Avatar
I've seen threads about remote boosters, also electric powered. Didn't pay to much attention to the topic, I run the boosted dual hydraulics.
Frankenstein57 is offline   Reply With Quote
Old 03-24-2012, 07:21 PM   #6
1pieceatatime
i never thought about the hydraulic booster. ive got an old chevy 1-ton out back with one on it so im gonna give it a try. thanks tdlmomower for the suggestion.
Old 03-25-2012, 02:36 AM   #7
40 Deluxe
Take a look at the early Bronco power brake setup. It angles to the left to clear the valve cover.
Old 03-25-2012, 08:23 AM   #8
tdlmomowers
Your Welcome. I just thought that a Hydro Boost unit is smaller than a regular booster. I had a hydro boost on an Astro van, and it worked well. Hope you get it worked out.
