Old 03-05-2012, 05:37 PM   #1
FRANK PKNY
FRANK PKNY's Avatar
Default 53 valve question
Trying to get a valve guide lock out of a 53 engine. Can't get the valve guide lock to come out , been releasing the spring pressure with the bar, via pushing it down and pulling the lock slightly down and out to no avail.
have done this mant times on the early style engines without a problem. Am I missing something? ThanksFrank
FRANK PKNY is offline   Reply With Quote
Old 03-05-2012, 06:48 PM   #2
Ronnie
Ronnie's Avatar
Default Re: 53 valve question
Remove the valve locks,remove valve,and drive the guide down.
Ronnie is offline   Reply With Quote
Old 03-05-2012, 07:07 PM   #3
ford1
buy or borrow the tool that goes past an open valve from the top, it then rests on top of the guide so you can drive it down to remove the horse shoe keeper, even with the keeper out you may still not be able to force the guide and spring assembly out of the engine
ford1 is offline   Reply With Quote
Old 03-05-2012, 07:11 PM   #4
Bruce Lancaster
I don't know if this relates at all to your problem...look at this picture:
http://www.vanpeltsales.com/FH_web/F...ve1949to53.jpg
On these late ones you have 2 pieces, labeled 6517 and 6514 here, to push up before you can extract the keepers
Bruce Lancaster is offline   Reply With Quote
Old 03-05-2012, 07:14 PM   #5
Bruce Lancaster
Oops...seems I was looking at the wrong end of the problem! Yes, guide HAS TO go down a ways before that retainer can come out as Ford intended.
If you are not worried about Ford's intentions there are both drivers and special pry bars of several types designed to force it out, ruining the keeper but often saving hours of work. There is always some risk with any of these of mangling the thing without actually getting it out.
Old 03-05-2012, 07:21 PM   #6
Jack E/NJ
Jack E/NJ's Avatar
Use spanner to pry 6514 up, push valve down to release 6517 and 6518 clip retainers. Then pull valve out. Push or tap 6510 guide down to release horseshoe clip 6512 from block recess. Image from VanPeltSales site. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 03-05-2012, 07:34 PM   #7
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
As Jack E N/Y says, remove the keepers and spring retainer from the bottom of the valve, then pull the valve out, then pry the spring over and down off the guide, now drive the guide all the way down with the horseshoe guide lock still on. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-06-2012, 04:36 AM   #8
Barry WNY
Solid stainless antenna, like '60's Mopar tougher than anything else. I heated & bent a tight hook about a 1/4" radius in one end to grab the horseshoe lock, handle loop on the other. You can pull seriously hard on locks and other stuck small stuff that I cannot recall right now.
Barry WNY is offline   Reply With Quote
Old 03-06-2012, 09:44 AM   #9
ford1
if you put any thing in the hole in the tab of the horse keeper and get real rough with it you will just tear the hole out, if the guide is stuck the only way to get the keeper out is drive the guide down and then remove the keeper, if you have the tool to drive the guide down past an open valve to remove the keeper, once the guide is moved when driving it down it will then come out the top with out trying to remove the valve keepers, they can be a pain to remove while in the engine
Old 03-06-2012, 11:17 AM   #10
FRANK PKNY
FRANK PKNY's Avatar
Thanks for all the help. Got it out. Used acatone and trans fluid, to desolve the crud and was able to pull the guide down and remove the clip. Sorry I have not been around here lately. Been laid up with recovering from surgery. Did a 1915 T touring last winter. Took The 35Cabriolet out last Sat. Shifting With My right toe. Frank
Old 03-06-2012, 12:27 PM   #11
Seth Swoboda
Seth Swoboda's Avatar
Frank, good to see you're back. I was wondering where you had been. Hope you're doing better.
Seth
Seth Swoboda is offline   Reply With Quote
Old 03-06-2012, 03:51 PM   #12
FRANK PKNY
FRANK PKNY's Avatar
Thanks Seth,
I'm doing good, had an accident putting the plow on my dump truck and tore the ligament off my shoulder, been 5 weeks in a soft cast one more to go then I can start doing light work with it. Hell to get old but better than the altertantive! Did you get your spare tire mount sorted out? I have the info you need in my hard records if you need it. Frank
Old 03-06-2012, 04:59 PM   #13
Seth Swoboda
Frank,
Yes we have the spare tire mount figured out and on the truck. We are nearly done, just the small details now. Can't wait to drive it soon. Glad to see you back and hope you get well soon. Those shoulder injurys take lots of time to heal. What are you going to put that 8ba engine in?
Old 03-06-2012, 05:49 PM   #14
FRANK PKNY
FRANK PKNY's Avatar
It's in a 53 Convertable that belongs to a friend. He baught it last year the engine was rebuilt by unkown party. One valve was not seated , had a miss with real low compression, did a blow down test and found the exhaust valve leaking. Will try to grind it in by lappng.
Old 03-06-2012, 06:56 PM   #15
Mike51Merc
Mike51Merc's Avatar
Make sure you examine the valve seat for cracks.
Mike51Merc is offline   Reply With Quote
Old 03-06-2012, 07:11 PM   #16
Big Red 51
Big Red 51's Avatar
Frank, Just curious, was the engine an EAB or an 8BA? I looked at 10 '53s last year and 75% of them had 8BAs rather than the EAB. Someone told me that in some plants they were using 8BAs rather than EAB because they had so many.
Don
Big Red 51 is offline   Reply With Quote
Old 03-06-2012, 10:45 PM   #17
Walt Dupont--Me.
Don
What's the differance from an 8BA and a EAB block? Walt
Old 03-07-2012, 09:29 AM   #18
Big Red 51
Big Red 51's Avatar
The EAB is rated at 110 HP and has a slightly different Camshaft which has a smaller diameter requiring a longer tappet. They were standard for 1952 and 1953. As I mentioned, someone told me Ford used the 8BA in some cases into '52 and '53. I think most 8BAs you find in '52 and '53 bodies were most likely replacements.
Don
Old 03-07-2012, 04:43 PM   #19
FRANK PKNY
FRANK PKNY's Avatar
Big Red I will look this weekend , I am working on it Sat. Frank
