Old 01-09-2012, 04:00 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default A taller distributor for belt clearance ??
After reading this thread
http://www.fordbarn.com/forum/showth...393#post340393
After a few phone calls etc we made up two chevrolet conversions with a 1 inch taller profile. Hopefully this is another method of solving the belt clearance issue????
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-09-2012, 06:01 PM   #2
36tbird
Default Re: A taller distributor for belt clearance ??
Bubba, you and I have traded e-mails. I am getting around the clearance problem using an idler pulley to bring the belt down under the distributor. What I have seen in trying to make the Chevy dizzy taller is that you run out of inside shaft length to go into the lower stabilizer fitting on what you previously called the Mercury type of timing cover. Are you making that shaft longer to make the taller housing?
36tbird is offline   Reply With Quote
Old 01-09-2012, 07:34 PM   #3
BUBBAS IGNITION
You are correct , the shaft isn't long enough for lower support, however the two we made are what I call"exacts" meaning the Chevrolet housing is covered by a tube then machined to the exact size of the ford factory unit.hopefully it will fit and run with or without the lower support....
I do like the support cover but there's no load on the ford distributor and the support really needed unless you plan on running a magneto.
We might find the shaft will need a graft about half way up to use the support?
[email protected]
Old 01-09-2012, 08:13 PM   #4
Ol' Ron
Ol' Ron's Avatar
I offered a solution to this problem a few months ago. However I like the idea of a longer distributor, I have one that's ahalf inch longer for an HEI unit I made 20 years ago.
Old 01-09-2012, 10:35 PM   #5
296 V8
Mr Bubba
I assume you could machine the chevy early mallory to fit 8ba and have it sit higher that the 8ba mallory?.
If so ... is there enough shaft on the chevy to use it in the merc cover and still have it sit tall?
296 V8 is offline   Reply With Quote
Old 01-11-2012, 10:15 AM   #6
bloodyjack
bloodyjack's Avatar
Bubba
I already have 2 of your dizzy's now I want a longer one for my next build.
I am squeezing an 8BA in a 31 coupe and do not want to cut the firewall.
After mocking up with new water pumps I will give you a call.
bloodyjack is offline   Reply With Quote
Old 01-11-2012, 12:09 PM   #7
BUBBAS IGNITION
Originally Posted by 296 V8 View Post
Mr Bubba
No the shaft is too short ,however we can do a shaft graft and make anything we need to fit the merc cover .
Its only money i guess????
And it s your money not mine..
[email protected]
Old 01-11-2012, 11:03 PM   #8
296 V8
Mr Bubba
Lookin at the chevy mallorys ... I have a ZC and a YC
The YC looks better to me ... no big lump on the side.
Thanks
Greg
Old 01-12-2012, 04:08 PM   #9
bloodyjack
bloodyjack's Avatar
Mallorys are not going to work even with an extra inch. I mocked it up and tried today.
This is a Chevy Mr mallory that Bubba modified for me to use with a flathead. It is not fully engaged and definatlly will not work.
In this picture the Mallory is not even in all the way
as you can see its not going to work, maybe one without the tach drive might work
Here is the regular bubba dizzy in my daily ride and as you can see add an inch and the belt can slide under there.
Old 01-12-2012, 08:53 PM   #10
296 V8
bloodyjack
It looks like the fan will clear the dist …. yes?
It also looks like an idler on the back side of the belt would get it under easy.
Im wanting to run a gen mounted fan w 8ba dist in my
35 coupe.
8ba motor (motors done … don’t want to change cams)
Early heads
Iv got the 8ba mallory and a gen and fan on now and it (the fan) is very close to the dist but I have room to shim fan out a bit.
Old 01-13-2012, 08:44 AM   #11
36tbird
I previously posted this in another thread. Still smoothing up the idler pulley assembly opposite the distributor and going to use a larger diameter pulley on that side. I mount the alternator in the lowest position and will adjust the bigger pulley to take in the slack. This engine is a 59A with a cam adapter gear and Roberts gear cover.
Old 01-14-2012, 06:21 PM   #12
hop up
hop up's Avatar
Sweet
Wanted Ford oiler oil cans Thanks
hop up is offline   Reply With Quote
Old 01-14-2012, 06:52 PM   #13
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Nice job 36Ford. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 01-14-2012, 08:52 PM   #14
Mark Slight
Mark Slight's Avatar
Ford never made a DIZZY, they did however make distributors!
Mark Slight is offline   Reply With Quote
Old 01-14-2012, 10:11 PM   #15
Binx
No disrespect intended, but the young'uns call them "dizzys". That term is here to stay if you expect the next generation to come on board. You have to admit, if they hadn't coined that phrase, you would have back in the day...
Lonnie
Binx is offline   Reply With Quote
Old 01-17-2012, 04:08 PM   #16
bloodyjack
bloodyjack's Avatar
Thanks Binx some people don't have informative content in there posts.
Old 02-06-2012, 03:21 PM   #17
bloodyjack
bloodyjack's Avatar
Just recieved my package from Bubba and it fits, just.
Now I just need to find an old style bottom pulley
Old 02-19-2012, 04:41 PM   #18
cadillacoffin
some of the problem with your set up bloody jack is that you have the early generator and water pumps causing the belt to ride closer to the block.
cadillacoffin is offline   Reply With Quote
Old 02-19-2012, 08:33 PM   #19
Ol' Ron
Ol' Ron's Avatar
That's true, but we must solve ALL problems,or, there's many ways to skin a cat.
