Old 06-19-2010, 05:11 PM   #1
glenn in camino
glenn in camino's Avatar
Default 28 drum tailight
What is the correct finish on the metal STOP sign inside drum tailight.
glenn in camino is offline   Reply With Quote
Old 06-19-2010, 05:15 PM   #2
Bobster
Bobster's Avatar
Default Re: 28 drum tailight
I bought mine from a reputable Ford source - it is red with "STOP" outlined in black on the inside of the globe. Does this answer your question? BW
BW in WV
Bobster is offline   Reply With Quote
Old 06-19-2010, 06:19 PM   #3
d.
Default Re: 28 drum tailight/ totally wrong
There was no Ford factory issued STOP (cut in the glass) lens. What you have is 70's bad repro. The original STOP was a die cut steel piece that is still offered by reputible dealers such as Bratton's. The STOP die cut piece is inserted between the lens and the stop light body with thin gaskets on both sides.
d. is offline   Reply With Quote
Old 06-19-2010, 06:41 PM   #4
Roadster62
Roadster62's Avatar
Haven't had an A tail light apart in a while, but the 26-27 T Factory STOP light had that piece cad plated.
Roadster62 is offline   Reply With Quote
Old 06-20-2010, 01:06 AM   #5
Rowdy
Not sure what the finish of the incert stop plate was originnally, but the one that I nearly have ready to sell here is now black. Still need to rivit the brake light contact back in then repaint the outside. Or atleast I would think that rivit was painted with the back of the licence plate holder. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
