Old 11-28-2011, 08:12 PM   #1
C26Pinelake
Unhappy Sponge packed around top of oil filler tube ?
I recently purchased a Cabriolet and there is a yellow sponge on top of the oil tube spout under the cap. It looks manufactured and is about one inch in diameter. The motor runs very well and there does not seem to be fumes or smoke comming out of the tube when sitting in the driveway idling. Ideas please and is there something I should do ? Do I have a problem ? Thanks Wayne
C26Pinelake is offline   Reply With Quote
Old 11-28-2011, 08:21 PM   #2
Mikeinnj
Mikeinnj's Avatar
Default Re: Sponge packed around top of oil filler tube ?
Sounds like you might have some blow-by problems. To find out, remove the sponge and take a spin at highway speeds and then check signs of any oil blow-by,caused by worn pistons/rings. If so, you may see some oil on the outside of the tube and the surrounding area caused by pressure leaking from the combustion chamber, past the piston rings and pressurizing the crank case, causing oil vapor to escape from the breather tube. Also check the dipstick to be sure the oil pan is not over filled.
Mikeinnj is offline   Reply With Quote
Old 11-28-2011, 08:49 PM   #3
Bill Lee/Virginia
IMO, I think it is too restrictive. I would do away with the sponge. I had excess blow-by that resulted in a very dirty engine compartment and lots of elbow grease to keep it clean. I took a hint from previous posts and use an old white sock over the cap and breather tube. I change the sock about twice a year, more often if it gets saturated between oil changes.
Bill Lee/Virginia Peninsula
Bill Lee/Virginia is offline   Reply With Quote
Old 11-28-2011, 08:54 PM   #4
glenn in camino
glenn in camino's Avatar
You need a Fumaze or other breather tube to control that blowby and keep your engine cleaner..
glenn in camino is offline   Reply With Quote
Old 11-28-2011, 09:08 PM   #5
C26Pinelake
Glenn Where do I buy a fumaze ?
Bill I have a white sock and that gets immediate installation !
Thanks guys !
Wayne
Old 11-28-2011, 09:10 PM   #6
bobpo
bobpo's Avatar
I use a Black Sock. Fits in better...
bobpo is offline   Reply With Quote
Old 11-28-2011, 09:15 PM   #7
48Ratfink
48Ratfink's Avatar
Any extra points if it's a Snap-on sock??
48Ratfink is offline   Reply With Quote
Old 11-28-2011, 09:37 PM   #8
BrianBurkert
BrianBurkert's Avatar
Be sure anything you put in the breather pipe will still allow the engine to breathe. If you stuff the cap too tightly, the crankcase can pressurize and push extra oil out the rear main. I've seen it happen.
BrianBurkert is offline   Reply With Quote
Old 11-28-2011, 09:44 PM   #9
C26Pinelake
I have a black and white sock with a hole in it so that should satisfy everyone.
Thank you all and I have enjoyed and learned from the responses !
Wayne
Old 11-28-2011, 10:38 PM   #10
John Duden
John Duden's Avatar
I have a oil cover with a hose (original accessary but not fumaze) if you are interested $25
John Duden is offline   Reply With Quote
Old 11-28-2011, 10:42 PM   #11
TinCup
TinCup's Avatar
White socks are easy but the Fumaze is a tough find. Took me almost 2 years before I found one. Search the forums and you will find a post with pictures I did earlier.
Thanks guys !
Wayne
TinCup is offline   Reply With Quote
Old 11-29-2011, 01:36 AM   #12
Chris Haynes
Chris Haynes's Avatar
Steel wool did the job on my '31 Sport Coupe back in the '60's.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 11-29-2011, 03:30 AM   #13
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Does anyone know where there is an advertisement of the Fumaze? I looked in "Those Wonderful Unauthorized Accessories" but could not find it.
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 11-29-2011, 09:29 AM   #14
1931 flamingo
1931 flamingo's Avatar
In the wanted section "JOOP" has a want ad with picture and I believe if you do a search here you may come up with a photo as the FUMAZE has also been discussed at great length before as well as "sock" additions to the oil filler tube.
Paul in CT
Old 11-29-2011, 10:40 AM   #15
TinCup
TinCup's Avatar
Here is the unit I just restored.
Click Here for more pictures.
Old 11-29-2011, 11:12 AM   #16
C26Pinelake
Please send your price to wayne at [email protected]
Old 11-29-2011, 11:44 AM   #17
MikeK
MikeK's Avatar
Bill Lee's comment about too restrictive and resulting oil out the rear main is well founded. A hard to find period accessory Fumaze is not the only answer to a clean engine compartment though. All the "A" parts vendors sell a knock-off of another style with a flex metal hose that will do the trick too. You may not need one at all. Another fix if you have only normal blow-by is to stuff a copper pot scrubber in the tube to catch and condense fine mist. Less restrictive than that cellulose sponge. Make sure you use a Copper scrubber, not a SS one. If a particle or two of copper get in the engine, no harm. SS will score things.
From the parts vendors:
MikeK is offline   Reply With Quote
Old 11-29-2011, 12:15 PM   #18
Clem Clement
Clem Clement's Avatar
If you use a sock, use your wife's. Because when the sock is done, it is all soppy and goey to wear(:>)
Clem Clement is offline   Reply With Quote
Old 11-29-2011, 12:55 PM   #19
John Duden
John Duden's Avatar
this is the one i have
john
Old 11-29-2011, 01:15 PM   #20
bogdonj
bogdonj's Avatar
This is what I use and works good!
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
