Old 11-06-2011, 12:14 PM   #1
GordonP
Default 1928 Pickup Bed
Will a 1928 Pickup bed fit on a 1929 Chassis?
GordonP is offline   Reply With Quote
Old 11-06-2011, 12:21 PM   #2
700rpm
700rpm's Avatar
Default Re: 1928 Pickup Bed
Yes.
Old 11-06-2011, 12:46 PM   #3
flatford39
Not only that, it will fit on a 30 31 frame as well. Most people get the 26 27 model T pick up box confused with the A's. Do you know for sure yours is a Model A box??
flatford39 is offline   Reply With Quote
Old 11-06-2011, 01:29 PM   #4
Charles Reese
Charles Reese's Avatar
some of the very early p/u beds mounted differently than the later style. in my case (1/28) the body subrails continue out from the cab and extend over the rear frame crossmember. this bed is slightly longer than the later style and its lower rails are stamped to fit directly over these body subrails .. i believe the later version (i don't know start date) mounts to wood stretchers and then to the frame.
Charles Reese is offline   Reply With Quote
Old 11-06-2011, 02:16 PM   #5
GordonP
Guys,
Thanks for responding.
What I have is a Model A Chassis, that much I'm sure of.
The pick up bed I have looks like the box on 28 A's in photos I've looked at. It has a "L" bracket on each side on the bottom front that doesn't line up with the frame. The comment that the subrails used to extend might be my problem, as the cab I have ends at the back of the cab.
I'm assuming I can mount this somehow, just didn't know if there was a trick.
GP
Old 11-06-2011, 02:37 PM   #6
Keith True
Keith True's Avatar
It sounds like you are missing the wood subrails under the pickup bed.Those L brackets don't line up with anything.
Keith True is offline   Reply With Quote
Old 11-06-2011, 05:40 PM   #7
Charles Reese
i agree with Mr. True .... you have the later bed and will need the long wood blocks ... major vendors have these
