Old 06-15-2010, 06:39 AM   #1
40ford
40ford's Avatar
Default 40 Trunk Lock:
I have a new trunk lock and having problems getting it installed.I am not sure how the pin release works.I keep thinking something is wrong with the lock.The key only comes out a one place.Should the cylinder make two revolutions and key come out?My handle never had a lock in it and not sure how it is suppose to work!Can someone explain? Thanks,Russell
40ford is offline   Reply With Quote
Old 06-15-2010, 06:47 AM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: 40 Trunk Lock:
On my Drake reproduction, straight up is locked and 1/2 turn to the right is unlocked. The key can only be removed in the locked position.
4dFord/SC is offline   Reply With Quote
Old 06-15-2010, 07:50 AM   #3
40cpe
40cpe's Avatar
It's a pain to keep locking/unlocking the trunk. I ground a key head down enough that the lock cover will close over the key. Leave it in the unlocked position until you need it locked, then remove the key.
40cpe is offline   Reply With Quote
Old 06-15-2010, 10:04 AM   #4
Bruce Lancaster
By pin release, do you mean the little pin that holds cylinder into the hole on a real Ford lock?? If so, from memory that becomes movable somewhere about 45 degrees from key just inserted and vertical. Get it to that area and adjust til you can easily depress the pin to insert, for removal adjust til you can depress it via the little access hole.
Bruce Lancaster is offline   Reply With Quote
Old 06-15-2010, 06:49 PM   #5
40ford
40ford's Avatar
Thanks Bruce,I figured it out and got the cylinder installed.I thought it could be unlocked with key out until needed.Like 40cpe said ,I think is a real pain but I will give it a try.
Old 06-15-2010, 06:55 PM   #6
39coupe
39coupe's Avatar
I find it to be a pain myself. I do like the key grinding idea and may give that a shot.
39coupe is offline   Reply With Quote
Old 06-15-2010, 07:02 PM   #7
mike in las vegas
mike in las vegas's Avatar
The grind down key sounds like a great idea, will give it a try on my coupe.
mike in las vegas is offline   Reply With Quote
