Old 10-18-2011, 08:50 AM   #1
Dick Deegan
Dick Deegan's Avatar
Default Slight clutch chatter
Good Morning All;
I have a slight clutch chatter and am trying to eliminate sources. I noticed that there is a lot of clearance between the trunion nut on the adjusting shaft and the clutch pedal.
Do you think that may be one of the sources of the chatter? If so, short of getting another clutch pedal, can I braze the hole and redrill it to the correct dimension.
Or does it not matter?
Dick
Dick Deegan is offline   Reply With Quote
