Old 10-18-2011, 08:50 AM   #1
Dick Deegan
Dick Deegan's Avatar
Default Slight clutch chatter
Good Morning All;
I have a slight clutch chatter and am trying to eliminate sources. I noticed that there is a lot of clearance between the trunion nut on the adjusting shaft and the clutch pedal.
Do you think that may be one of the sources of the chatter? If so, short of getting another clutch pedal, can I braze the hole and redrill it to the correct dimension.
Or does it not matter?
Dick
Dick Deegan is offline   Reply With Quote
Old 10-18-2011, 08:57 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Slight clutch chatter
Clutch chatter is generally only from the clutch disc mating to the spinning flywheel surface. On almost every one of the Model A's that come in complaining about clutch chatter, I found an excessively worn pilot bearing and/or a worn transmission input shaft. Some say that a warped pressure plate will cause this too but that has not really been my experiences. The worn input shaft/bearing allows the clutch disc to engage 'out of centerline' which creates the jumping or grabbing that we generally associate as "clutch chatter".
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 10-18-2011, 09:46 AM   #3
Dick Deegan
Thanks for your insight Brent. I'll just leave the adjusting shaft, trunion and pedal alone.
Dick
Old 10-18-2011, 11:21 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Shortly after installing float-A-motor rear motor mounts in our coupe, many years ago, we started to experience clutch chatter. You can cushion away the chatter by retarding the spark a bit more untill you get the car moving. This could save a lot of work and money.
Old 10-18-2011, 11:41 AM   #5
V4F
V4F's Avatar
i have the same problem with float/motor mounts ........... steve
V4f
V4F is offline   Reply With Quote
Old 10-18-2011, 01:32 PM   #6
Dick Deegan
Purdy and Steve;
I also have FAM's. I will try retarding the spark until I get on the move, but I don't advance it very much from a start as it is. How tight do you fasten the bolt on your FAM's?
Thanks for the input.
Dick
Old 10-18-2011, 02:58 PM   #7
85930tudor
85930tudor's Avatar
Send a message via Yahoo to 85930tudor
Brent is right on about this. And you may have oil on the clutch disk...Dave
85930tudor is offline   Reply With Quote
Old 10-18-2011, 08:03 PM   #8
Purdy Swoft
I don't think so !!! Any real model A mechanic will tell you, if the tip of the input shaft is worn very much it will cause the transmission to jump out of high gear. I can't imagine the tip of the input shaft being worn enough to cause clutch chatter. Theory can be all over the place but If the pilot bearing and input shaft was worn enough to cause clutch chatter, you probably wouldn't be able to keep it in high gear. It may have oil on the clutch or it may not actually be clutch chatter at all. Sometimes without the original solid rear motor mounts the engine will slightly jump around apon take off and this chatter is often reffered to as clutch chatter. Model A's dont have the anti chatter rods like the early V8' s and with closed drive the hole drivetrain will float if float-a-motor mounts are used.
Old 10-18-2011, 08:10 PM   #9
V4F
V4F's Avatar
if i remember correctly , they have a steel collar like the wish bone . tighten untill tight . if im wrong i do appologize . ive only wored on them twice . how is the tail shaft held ? mine is a 5 speed & it has a cross member to tighten to ............... steve
V4f
Old 10-18-2011, 09:55 PM   #10
BRENT in 10-uh-C
Mr Swoft, you're probably right. Maybe one day I will get enough experience working on Model A's to be considered a "real Model A mechanic." Until then, I will yield to your expert advice and experience.
BRENT in 10-uh-C
