Old 08-16-2011, 08:00 PM   #1
28 Special Coupe
28 Special Coupe's Avatar
Default Brass GAV Seat Question
I have an older Zenith carb with the brass GAV seat. When I first got the car, the GAV dial inside the car would point straight up when it was fully closed. After I had a fellow club member rebuild the carb, it no longer does. It now points toward the 2 o'clock position when closed.
I found that if I screw the seat out about 3/4 turn, I can bring the dial back to the 12 o'clock position when closed. My first question is, am I being too nit picky? And my second question is, am I going to create problems by not having the seat tight? Is there a better way to line it back up or should I not worry about it?
Thanks for you help.
28 Special Coupe is offline   Reply With Quote
Old 08-16-2011, 08:18 PM   #2
mot
Registered User
mot's Avatar
Default Re: Brass GAV Seat Question
he may have replaced the seat with a new one
it may be a different height
or he may have replaced the needle valve with a new one
maybe the old one was scored and worn out
ask him
mot is offline   Reply With Quote
Old 08-16-2011, 08:27 PM   #3
JoeWay
JoeWay's Avatar
Originally Posted by 28 Special Coupe View Post
...My first question is, am I being too nit picky? And my second question is, am I going to create problems by not having the seat tight? Is there a better way to line it back up or should I not worry about it?
What Mot said....
Yes, yes, no, and yes.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 08-17-2011, 02:48 AM   #4
dave in australia
My GAV seats at 7 o'clock, it doesn't matter where, as long as it does.
dave in australia is offline   Reply With Quote
Old 08-17-2011, 12:26 PM   #5
28 Special Coupe
Well, I figured I was being too nit picky, but I like things to look right if at all possible. I guess I better screw the seat back in tight and not worry about how it looks.
Thanks for your replies.
