Old 08-15-2011, 10:12 PM   #1
Ol' Ron
Ol' Ron's Avatar
Default Toyota 5 speed
Recently I was told that the Toyota 5 speed can be adapted to out flathead. I was wondering if anyone has done this?
Old 08-15-2011, 10:24 PM   #2
Brendan
Brendan's Avatar
Default Re: Toyota 5 speed
in china thay do that ! lol
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 08-15-2011, 10:38 PM   #3
meric42
meric42's Avatar
Yes, I bought one strapped to an 8BA with a 3x2 manifold and hot cam. It came out of a '52 Fordor from Australia that a friend of my brother owned, I was told it went really strong. I never got to find out though, had to sell it to fund another project.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 08-15-2011, 10:50 PM   #4
kiwitony
kiwitony's Avatar
Yes I run a toyota 5 speed in my 37 pickup, had it in there over 10 years.Cast iron box is a w50 all ali a w55.They can handle up to 300 odd horses so a flatty is never going to worry it.Cheers Tony.
kiwitony is offline   Reply With Quote
Old 08-15-2011, 10:51 PM   #5
Fe26
I too have been in contact with a guy here in OZ who is running a flathead with a Celica 5 speed (a very good and strong gearbox). He told me he wouldn't use that model again as it is quite a long gearbox, and that he had/has trouble with the gear shifter coming out of the floor hard against the seat.
Fe26 is offline   Reply With Quote
Old 08-15-2011, 11:00 PM   #6
frederic
What sort of adapter do you use to mount the toyota 5 speed to the flathead
thanks
frederic is offline   Reply With Quote
Old 08-15-2011, 11:17 PM   #7
meric42
meric42's Avatar
From memory the 5-speed was just bolted to the original '52 Ford transmission bell-housing.
Old 08-15-2011, 11:20 PM   #8
wga
wga's Avatar
Flathead Jack had the pieces for the conversion at one time...
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 08-16-2011, 12:51 AM   #9
296 V8
http://www.flatattackracing.com/
296 V8 is offline   Reply With Quote
Old 08-16-2011, 02:28 AM   #10
34 TUB
34 TUB's Avatar
Mike Davidson of flatatack racing products from South Australia makes the adapter and a lot of other really nice flathead products. I have one that I’m going to run in my 34 phaeton
34 TUB is offline   Reply With Quote
Old 08-16-2011, 04:56 AM   #11
Blownflatheaddeuce
Blownflatheaddeuce's Avatar
I have one behind my blown 8BA in a 32 2W here in Melbourne AUS.
I used a cast iron 8BA bellhousing that required the bottom holes in the bell to be redrilled to suit the Toyota/Jap 5 speed.
I run a Heavy Duty Toyota clutch and the I have OD in 5th. Very nice !
Works brilliantly !!
PM me if you need any info Ron.
Rat
Blownflatheaddeuce is offline   Reply With Quote
Old 08-16-2011, 05:17 AM   #12
coupe5w36
coupe5w36's Avatar
I'm running a "cast-iron" case Celica box behind my 8BA & yes, the gearlever is a little further back than I prefer. It's not a big deal though & is smooth & pleasant to operate. We adapted the box using a plate & a pressed steel bell-housing. If I was doing it again, I'd probably use a Supra box & one of the Flatattack bell-housings. Previously I had a Celica box behind a strong 302 (in a '32 roadster) & stripped 5th gear accelerating up a long hill with a teardrop on the back (so too much torque is a definite problem!!), but no worries behind a flathead (well, my flathead anyway)
coupe5w36 is offline   Reply With Quote
Old 08-16-2011, 07:43 AM   #13
40cpe
40cpe's Avatar
maybe there are several versions of the Toyota Overdrive, but I had a pickup 4 cylinder that was only something like .91 in OD. Our Lexus IS 300 is the same way, only drops the rpm about 300 in 5th. I would want the .72 overdrive if I went to that much trouble.
40cpe is offline   Reply With Quote
Old 08-16-2011, 09:10 AM   #14
Ol' Ron
Ol' Ron's Avatar
This is very interesting, it's nice to see there are other options for us hot rodders. I was talking to a fellow yesterday that is planning on using one, will have to check it out.
Thanks
Ol' Ron
Old 08-16-2011, 12:06 PM   #15
Chris Nelson
Chris Nelson's Avatar
You also might try the website; www.flat-o.com Gene Benson makes T-5 & S-10 transmission adapters as well as the C-4 automatic trans. package for the flathead.
Chris Nelson is offline   Reply With Quote
Old 08-16-2011, 01:49 PM   #16
34Fordtk
34Fordtk's Avatar
Besides the Celica what Toyota does this transmission come from?
31 Coupe
34Fordtk is offline   Reply With Quote
Old 08-17-2011, 04:25 AM   #17
my4dv8
Yup, not too proud of having a toymota 5 speed in our blown flat motored 37 coupe, but with a 3.5 diff and a early cast iron / aluminium celica 5 speed it is a nice cruiser.
We found a flathead gearbox that someone had already cut and just used the bell housing part as an adapter .Flathead clutch etc with the toyoa spline welded into the flatty clutch plate. Found a box with a reasonably forwar mounted stick. We drilld some new mounting holes in the old belhousing and it was a super easy swap.
my4dv8 is offline   Reply With Quote
Old 08-17-2011, 08:51 AM   #18
4-barrel Mike
Or try Mac's in New Zealand for more "traditional" adapters: http://www.macsspeed.com/adapters_2.html
Mike
4-barrel Mike is offline   Reply With Quote
