Old 08-14-2011, 08:33 PM   #1
Vanspeed
Vanspeed's Avatar
Default Trico rebuild questions
I got caught in the rain in the 47 pickup yesterday and my trico has long since worked so I thought a rebuild is in order. I have it all apart and I am wondering what kind of grease is used in these? The original grease is redish in color, what can I buy that that will work in the rebuild? No parts houses mention it.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 08-14-2011, 08:45 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Trico rebuild questions
Vasoline works for me.
Old 08-14-2011, 08:51 PM   #3
Vanspeed
Vanspeed's Avatar
Vasoline huh, I will give it a try. How much do I use??
Old 08-14-2011, 09:18 PM   #4
Lawson Cox
Lawson Cox's Avatar
Just coat things lightly.
Old 08-16-2011, 12:37 PM   #5
forty-niner
clean gook from between leathers with a pick
use no strong solvents that might dry leather
good luck
forty-niner is offline   Reply With Quote
Old 08-16-2011, 02:52 PM   #6
~~Walts37~~
~~Walts37~~'s Avatar
I used vaseline also but used a lot of vaseline with a very heavy coat mine still working great after 4 years of use with no problems
~~Walts37~~
~~Walts37~~ is offline   Reply With Quote
Old 08-16-2011, 03:16 PM   #7
40cpe
40cpe's Avatar
~~Walts37~~
Did you put a kit in it or just clean and coat with Vasoline?
40cpe is offline   Reply With Quote
Old 08-16-2011, 05:17 PM   #8
~~Walts37~~
I just took it apart after it had sit in a pasture for 35 years cleaned everything up & applied Vaseline to all moving parts left a little extra inside I think I had to make a new gasket & put it back together works great.
~~Wallts37~~
Old 08-16-2011, 08:48 PM   #9
OldDad
OldDad's Avatar
Used silicone grease in mine in 1985, then car sat for 25 years indoors. Thought I would have to go through it again, but it still works fine. I used just enough to coat the paddle and lube the inside of the housing.
OldDad is offline   Reply With Quote
Old 08-17-2011, 07:08 AM   #10
36Bill
36Bill's Avatar
I just filled mine with 3 in 1 oil and let it sit for a day. Drained out the oil and put in a new line, works great. That is after for 38 years.
Bill
36Bill is offline   Reply With Quote
Old 08-17-2011, 09:06 AM   #11
David W Juliano
Not much to rebuilding one, but the gaskets are a problem to make. Anyone know of a source for rebuild kits, especially the gaskets.
David W Juliano is offline   Reply With Quote
Old 08-17-2011, 06:44 PM   #12
Vanspeed
Vanspeed's Avatar
Mac's has the gaskets and full rebuild parts. I just used some vasoline and put it back together with a rebuild kit. It works! I can actually make it move back and forth by sucking in on the inlet tube. Must have done something right.
