Old 08-12-2011, 06:47 PM   #1
jkcrosson
jkcrosson's Avatar
Default Nagging chirp
I've got a chirp in my engine compartment. It seems to be coming from the front motor mount. It's not the generator, water pump or belt. It does not do it at low rpms or high rpm. Seems to get worse while the clutch is depressed. I can make it stop chirping by pushing a little on the front carb side of the engine. I've narrowed it to the front motor mount. I've tightened the front motor mount bolts. Please help. I love the sound of the engine but I am tired of the "Crickets".
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 08-12-2011, 07:10 PM   #2
RcT
Default Re: Nagging chirp
Does it seem to coincide with the engine revolutions? Try something easy first, like a bar of soap on the belt when it is idling and see if it goes away... maybe the belt or a pulley is a bit glazed.
RcT is offline   Reply With Quote
Old 08-12-2011, 07:13 PM   #3
jkcrosson
jkcrosson's Avatar
Soap on the belt doesn't help. Not necessarily with the revolutins, it's more of a vibration chirp. Like I said, I can apply a little force to the side of the engine with a little lifting pressure and it will stop.
Jamie Crosson
1929 Tudor
Old 08-12-2011, 07:32 PM   #4
John Stone
John Stone's Avatar
It might be the front motor mount. Try a little oil about the center bolt.
John Stone is offline   Reply With Quote
Old 08-12-2011, 08:11 PM   #5
Jim Parker Toronto
Jim Parker Toronto's Avatar
It probably IS the front motor mount. Spray it good with WD40 so it is saturated, not only on top, but on the bottom as well. Then apply some oil.
Jim Parker Toronto is offline   Reply With Quote
Old 08-12-2011, 08:20 PM   #6
jkcrosson
jkcrosson's Avatar
Surely I have fought this for days and its as simple as oil on the front motor mount. I'll try it in the morning.
Jamie Crosson
1929 Tudor
Old 08-12-2011, 08:20 PM   #7
Brother A
Brother A's Avatar
Are you married?
Brother A is offline   Reply With Quote
Old 08-12-2011, 08:22 PM   #8
jkcrosson
jkcrosson's Avatar
Originally Posted by Brother A View Post
Are you married?
Yes and I knew someone would go in the direction with this post. LOL.
Jamie Crosson
1929 Tudor
Old 08-12-2011, 08:34 PM   #9
jkcrosson
jkcrosson's Avatar
Well, I got so caught up in diagnosing a "Model A Problem" i completely left common sense on the side of the road. Oil on the motor mount solved the problem. Sorry for posting a Silly question but I guess "i couldn't see the forest for the trees"
Jamie Crosson
1929 Tudor
Old 08-12-2011, 09:30 PM   #10
Ned
Had the same problem, oiled the front motor mount, no more chirp.
Ned is offline   Reply With Quote
Old 08-12-2011, 09:38 PM   #11
RTC1930
RTC1930's Avatar
Ditto here too.
"Fix what's broken"
RTC1930 is offline   Reply With Quote
Old 08-12-2011, 11:02 PM   #12
Gary WA
Gary WA's Avatar
Lifting engine as you said could it be a chirping rear mount rubber pads?
www.whidbeymodelaclub.com
